Question about Carrier 30HXC096 Indoor Water-Cooled Screw Chillers (30H-XC096, 30H XC096)
Carrier Screw chiller Model number PGI 225 -Y920 ,Ineed Trouble Shooting
  • 132 Answers
You really need to talk to the carrier people for a solution here.
There are too many variables to be sorted out to give you a solution on line
Posted on Mar 25, 2011
Carrier Chiller has fault code U65
What is the model number?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 23, 2017 | Carrier Heating & Cooling
Willthe canon PGI-225 CLI-226 fit a canon MP830 copier
i have a Canon PiXMA MP830 and PGI-5 Black and CLI-8 Black and Colors fit into it. Im not sure about the ones you are asking about, but i noticed jackie1969uk did not add that the printer does take other ink as well.
Apr 11, 2013 | Canon PIXMA Office Equipment & Supplies
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
My Carrier Home Central Air Conditioning Model Number 38CKC036 340 fan out side the house is not working it gives oout a low humming sound and fan doesnt rotate Serial Number 4698E05846 Manufacturer...
If the fan is humming and not running them it has gone bad....it will need to be replaced...not all that difficult a job...most pro's do it in less then an hour...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 11, 2010 | Carrier 38CKC036 Air Conditioner
One horsepower is how many ton? I want to know how many tons of refrigerant is equivalent to one horsepower capacity of a cooling system.
1 to 1...
1 hp. equals 1 ton or 12,000 BTU's....at least in round numbers...
this can vary just a bit depending on the combination of condensers and evaporators...
heatman101
May 25, 2010 | Carrier 30HXC096 Indoor Water-Cooled Screw...
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
Part no. expansion valve of Air cooled chiller
On a chiller with semi hermetic compressors can have different types of thermostatic expansion valves for metering. As far as a number, you will have to go to the evaporator to look at the tx valve and get the numbers. It may be a single ported, double ported, be externally equalized or not. You have to get the copper line sizes in and out also if you are planning to change the valve out. The valve will also have the type of freon the system uses if for some reason the data plate is worn off. That's the place to always find out is the expansion valve. If you need information other then what I have given you, contact me and I will help you.
Sincerely,
Shastalaker7
Mar 15, 2010 | Heating & Cooling
Sometimes compressor breaker is tripping. Breaker is 88A and compresssor FLA is 95A. Is this correct and if it is what could be the reason for tripping. Checked the wire connections, comressor windings and...
Breaker is to small , if the full load amps of the unit is 95 amps , to correctly size the breaker to code multiply the full load amps by 175% minimum and 225% maximum. A 200 amp breaker is the size breaker that I would recomend for this application.
Aug 03, 2009 | Heating & Cooling
Refrigerators Logo
182 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Davor Krstevski
Davor Krstevski
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
