Question about Hotpoint WMA40 Front Load Washer
The drum on my wma 40 seems to go tight any ideas why
  • 822 Answers
May have something stuck between the inner and outer drum...... socks tights and womens skimpies very easily slip down at the bottem door seal.... afraid the machine needs a total strip down if this is the case. remove the door and front panels, the drum has a front cover held on by a number of clips..... remove all clips take cover off....find said item and put back together shouldnt take more than an hour.. if it isnt that,.then rear bearing could be shot at,, sorry
cheers
Posted on Mar 24, 2011
Hotpoint Aquarius WMA 52P - My machine makes a lot of noise on the spin cycle. Any ideas?
definatly the drum bearing its common with those washers some repair men will do it for £80 thankyou
Jan 13, 2011 | Hotpoint Aquarius WMA52 Front Load Washer
T701 dryer makes a tumping sound. I turned the drum from the front panel area and the drum moves a little but I think it always has. I turn the drum with the belt and it seems to be tight. Any...
Hi Gary,
Since you are able to turn the drum with the belt, I am assuming that you have removed the cabinet of the dryer.
Look for worn bearings and support wheels for the drum. Also have a look at the idler / tension wheel as well.
The drum should not be moving around as it is sitting on the rollers. The belt should maintain enough tension to keep it from doing so. If it is able to be moved, there may not be adequate tension from the idler wheel.
Sep 18, 2010 | Asko T701 Electric Dryer
How do you remove drum springs on a hotpoint WMA washing machine
working from the front using mole grips get hold of the suspension peg now feel round the back you should feel a raised part of the peg this has to be depressed now pull the peg out if it gets stuck push back 5mm and try again repeat on other side life the springs out with the drum
hope that helps
May 13, 2009 | Hotpoint WMA64 Front Load Washer
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Hi,we have aBeko WMA 1512 Eco case washing machine,it is coming up for 2yrs old. It will take on water and the control switche moves as required to empty, but drum does not move,it's like it goes through...
I suggest the next step is to check the motor brushes. Take belt off and undo bolt at right hand side of motor .Allow motor to pivot down and then pull to remove. Brushes are located at back of motor in plastic housings. If worn down to housing they will need replacing. Any problems dont hesitate to ask.
Nov 16, 2008 | Washing Machines
REFITTING THE BELT ON HOTPOINT WMA 40
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Sep 03, 2008 | Hotpoint WMA40 Front Load Washer
Vibration problems
hiya
it could be a number of problems which are very common on the entire wma range.
1, drum bearings are really poor in these.
2, concrete block tapping, sometimes the bracket n the drums snap.
3, motor bracket snapped causing tapping.
i've found the plastic drums seem to be quite weak on the wma range to be honest so will more than likely be one of the above.
hope this helps
Jul 09, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Machine banging when in fast spin
or the three legged spider that attaches to the drum. its made of cheap metal and one or more legs can crack or break letting the drum loose - seems like bearing but isn't! cost about £40
Sep 28, 2006 | Indesit W 123 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
