HI I HAVE GOT A PROBLEM WITH MY KANGOO CAN ANYONE HELP IT STARTS AND DRIVES BUT DONT SEEM TO HAVE ANY POWER I HAVE CHANGED THE DIESEL FILTER AND AIR FILTER BUT IT IS STILL THE SAME NO POWER I CAN JUST BOUT DO 60MPH THE SERVICE LIGHT IS ON AND THE AIRBAG LIGHT WHAT DO I NEED TO DO TO PUT THESE OUT OR IS IT PART OF MY PROBLEM PLEASE HELP
    Master:
  • 344 Answers
For one.. you posted this incorrectly. But non the less. It sounds like your having an issue with something in the main processor. Take it to Advanced auto or Autozone and see if they'll plug it into one of their nifty readers and tell you what needs to be done.
Posted on Mar 24, 2011
How can I sort glow plug light problem on Renault Kangoo 1.5Dci? Initially it extinguishes as it should after a few seconds. It comes on when accelerating, and if accelerating hard, seems to reduce po
This is a common problem with these vehicles, most likely to be a faulty rotor sensor on the fuel pump but can sometimes occur due to dirty connectors within the relays and related wiring. The rotor fix isn't a major deal.
Dec 01, 2014 | 2005 Renault Kangoo
Pete, if you get no code from a reader, it only means it is a physical problem and not in the system. You could possibly just have a dirty connection at one or all glow plugs power wires. This wouldn't change the mpg at all. The EGR, if faulty diaphragm, would cause a loss of power, but that's mainly on a gasoline engine. Not sure on diesel unless the EGR is in the center of the air inlet of manifold. I removed my intake on my old Chevy 6.2 diesel and replaced it with an open one from a higher performance 6.2 and it gave it much more power because now there's no air restriction because no EGR is in the intake. This stopped the excessive smoke from exhaust also. That's just MY experience, and I just LOVE diesel.
The water in diesel light and service is on?
Change diesel filter and engine oil & filter , air filter, check timing belt, brake pads and shoes then you should be good to go. Diesel filter is a must !!!!!
Jun 07, 2014 | 2005 Renault Kangoo
Kangoo heater not working
sounds like heater core could have a restriction
Dec 05, 2013 | 2000 Renault 181
LDV MAXAS PLATINIUM, 2006, 120BHP, 2.5 Does anyone
Hi
I would have though your garage would have either cleaned or replaced the aur mass sensor.
You can find this four/five pin plug somewhere between the air filter and the throttle housing or google its location.
These often dont show up well on diagnostic computers.
You can run engine with plug disconnected to see if it runs better or not. If it does then buy and fit a new sensor.
All that really controls your fueling is coolant sensor and air sensors....these often fail the most.
Good luck
Roger
Apr 24, 2017 | Cars & Trucks
Did u sort our problem ???? My Engine is very down on power my 2005 x5 diesel takes 14 seconds to reach 60mph ,, and should do it in about 8.5 its very sluggish and power difference is insane...
I would say that having checked the fuel and air filters that theres a stong possibillity the turbos not kicking in, dont forget an x5 is a big lump and without a turbo the result would be as you describe. regards KSK
Feb 20, 2011 | 2005 BMW X5
I HAVE A 2001 DIESEL HOLDEN RODEO, AND A SMALL AMOUNT OF AIR IS GETTING INTO THE FUEL SYSTEM, EVERY DAY I HAVE TO PUMP THE PRIMER PUMP, TO EXPELL THE AIR BACK TO THE FUEL TANK, IF I DONT DO THIS IT BUILDS...
have seen new fuel filters not seal properly, due to warpage of seal flange gets bent when removing old over tight filters, check both filter & water trap, also bleed bolts on filter housing, use clear plastic hose between components to find where air ingress is coming from
Apr 17, 2009 | 2004 Isuzu Rodeo
Loss of Power from a Mitsubishi 1.9 DiD engine
Hi, check the air filter. Have helped friends in the past who have poor running vehicles that have been regularly serviced by a garage. I looked at them, found the air filter black with dirt....totally clogged up....never been changed since new!!! Many garages seem dont seem to bother changing it when they should!!! Cars need air to work (more air than fuel) so try this. Paul
Feb 09, 2009 | 2003 Mitsubishi Lancer
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
