Question about GE 25952 Cordless Phone
I have this phone but I can't get the second phone to work. The base works fine.
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
First, you can click on this link to view the user manual for your phone:
http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf
The user manual is in PDF format and may take a minute for it to load the page on your screen.
If you need a PDF reader to view the page, you can download one here for free:
http://get.adobe.com/reader/
You state that you cannot get the second phone (handset?) to work. However you didn't specifically state the problem you're having. (ie., (1) won't turn on, (2) turns on but won't work with the other phone, (3) won't ring or (4) have a dial tone but won't dial out, etc.) So, I'll try a few solutions:
If the problem is that the phone will not turn on, check or replace the battery. You may be able to purchase a new one on eBay for less money.
If the Handset can not link to the base, your phone's manual instructs as follows:
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
Setting Up the Handset:
There are nine programmable menus available: Language, Handset Name, Area Code, Ringer ON/OFF, Ringer Tone, VIP Ring Tone, Tone/Pulse, Transfer and Default Setting.
During programming, you may press the mute/menu button at any time to go to the next option. Pressing mute/menu button takes you through the menu choices. When changes have been made to selected menu item, pressing the mute/menu button saves the changes and Confirmation Tone sounds. To exit the menu and keep the previous setting and return to the standby mode, press the *EXIT/tone button.
Display Language
1. Press the mute/menu button until 41ENG 2FRA 3ESP shows in the display. 1ENG is the default. (ENG stands for English. FRA stands for French. ESP stands for Spanish.)
2. Use the CALLER ID-VOLUME (5or6) button or the touch-tone pad on the handset to enter your selection.
3. Press mute/menu again to save.
Handset Name
1. Press the mute/menu button until ENTER NAME shows in the display.
2. Use the touch-tone pad to enter the name (up to 15 characters). More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press th e 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
NOTE: If you make a mistake, use the chan/delete button to backspace and delete one character at a time.
NOTE: If no name is entered, READY shows in the display.
Local Area Code
This program setup allow you to setup how the incoming caller ID show on the display.
1. Press the mute/menu button until AREA CODE - - - shows in the display. "- - -" is the default.
2. Use the touch-tone pad on the handset to enter your three digit area code.
NOTE: If you make a mistake, press the chan/delete button to erase a wrong number.
Ringer ON/OFF
1. Press the mute/menu button until RINGER 41 ON shows in the display. 1ON is the default.
2. Use the CALLER ID-VOLUME (5or6) button or the touch-tone pad on the handset to scroll to 1 ON or 2 OFF .
3. Press mute/menu to save.
NOTE: If you turn the ringer off, RINGER OFF shows on the display.
Ringer Tone
You can choose from 10 ringtones.
1. Press the mute/menu button until RINGER TONE 401 shows in the display. 01 is the default.
2. Use the CALLER ID-VOLUME (5or6) button or the touch-tone pad on the handset to select from 01 to 10.
VIP Ring Tone
This feature allows you to assign a specific ring tone to a number stored in Memory. It is recommended that you store a Caller ID record into Memory for this purpose.
1. Press the mute/menu button until VIP RING TONE shows in the display.
2. Press the desired memory location (0 through 9). If there is a number stored in the selected memory location, VIP RT 4DEFAULT shows in the display.
3. Press CALLER ID-VOLUME (5or6) on the handset to select from 01 to 10 or DEFAULT to use ring tone set in the Ringer Tone Menu or SILENT to silence ringer.
4. Press mute/menu to save.
Without specific information from you as to exactly what is not working properly, all I can do is to refer you to the user guide (see link above.)
Please reply (by selecting comment) if you need further assistance.
Posted on Mar 24, 2011
  • J. Van
    J. Van Mar 24, 2011
    Please remember, in order to to re-register the phone (handset) place it on the MAIN BASE for 20 seconds (not the charger base.)
My main phone sitting on answerphone base is permanently 'engaged' therefore unusable. Second phone working fine as is answerphone. Please help?e
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
It also might help if you could specify the make and model of your phone.
Thank you for using FixYa.
Nov 28, 2011 | Lands Phones
Hi, I have a vtech phone model ia5823 which works fine. I have been given another phone and base to use as a 2nd phone exactly the same model. I have charged the 2nd phone but it cannont connect to the...
Take the first phone off from the base and turned of.Unplug the power from the base. Put the second phone in the base. Plug in power in the base. The base must search the new " IP or code "of the second phone. Turn on now the first phone , you should hire a small beep on the base or the unit and should be OK. Both must working now. I wait for an answer.
May 08, 2011 | Cell Phones
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Caller ID has aparently stopped working
Based on a user's review of this phone system on Amazon, I unplugged the base station, waited a few seconds and then plugged it back in. Caller ID display and announcement both work fine.
Mar 23, 2009 | Panasonic KX-TG5777 Cordless Phone
E17 and V141
I had the same problem after I moved to my new home.... The main E2600 base/machine/phone worked fine, but the satellite phone did not. It just kept flashing E-17.
I took the batteries out for a few seconds and reinstalled, and when I put the phone back on the satellite base, it found the main base and worked fine.
Hope this helps.
Dec 31, 2008 | AT&T E2600B Cordless Phone
Unavaiable second phone
Placed the second phone on the main base and it seemed to reset and now works fine.
Dec 15, 2008 | GE 25952 Cordless Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
No link to base
The solution works!
Thanks.
Feb 15, 2008 | Panasonic KXTG2344 Cordless Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
GE 25952 Cordless Phone Logo
71 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
