Question about Inter-M PA-2000 A Amplifier
I have an Inter-M Power amplifier model M-2000 2 x 1000 watts @ 4 ohm. But I have a problem with the power transformer. Can you send me output voltages of power transformer? Thanks E-mail: ohabem@yahoo.fr
  • ohabem Jun 16, 2011
    I need the output voltage values of the power transformer to fix it. The source voltage is 220 volts - 50 Hz. Please, send me the output voltage values of the power transformer to help me fix my Inter-M amplifier model M-2000.
How many Watts is the A1300HCQ AUDIOBAHN amplifier
  • 2400W Max, High-Current Monoblock Car Amplifier
  • RMS Power Rating:
    • 300 watts x 1 chan. @ 4 ohms
    • 600 watts x 1 chan. @ 2 ohms
    • 1200 watts x 1 chan. @ 1 ohm
  • Max Power Output: 2400 watts @ 1 ohm
Dec 18, 2014 | Car Audio & Video
How many Watts is the a1300hcq Autobahn amplifier
A1300HCT Max Watts:
  • RMS Power Rating:
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
What is the output of the 451s rms power
Dynamic Power Rating (measured at 14.4V):
  • Bridged Into A 4-Ohm Load: 450 watts x 1
  • Per Channel Into A 2-Ohm Load: 225 watts x 2
  • Per Channel Into A 4-Ohm Load: 115 watts x 2
Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
I need an owner's manuel for a Pioneer stereo power amp SPEC-4. I have a part # ARB-235. I think this amp is a product of the 1970's. Where would I be able to get my hands on the operating instructions?...
You can register with hifiengine.com andfind it and the service manual.
There really isn't a lot to a power amp to be operated. This one differs from most in that it has an input level control and VU meters.
From http://images.google.com/imgres?imgurl=http://www.incomesixdigits.com/spec4/spec4a.jpg&imgrefurl=http://www.incomesixdigits.com/spec4/&usg=__WbFLwPqHXjFHe_P2BCKyTT9CxQY=&h=652&w=1156&sz=526&hl=en&start=2&um=1&itbs=1&tbnid=5SVKh2leUGWXmM:&tbnh=85&tbnw=150&prev=/images%3Fq%3Dpioneer%2Bspec%2B4%26hl%3Den%26rlz%3D1R2ADFA_enUS360%26sa%3DX%26um%3D1
Dynamic 150 + 150 Watts Power Output, Generous High-power Design
The Spec-4 employs DC construction which excludes capacitors from the NFB circuits and uses a dual transistor differential amplifier with a current mirror circuit in the 1st stage. This provides a stable operation and also high gain over a wide frequency range. The pre-driver stage is a class A amplifier circuit with a regulated current circuit for the load. This makes for high-gain amplification with superior linearity. Furthermore, there is an overdrive limiter and power limiter circuit which is designed to protect the power transistors and make for added reliability.
The power stage employs a 3-stage Darlington pure complementary parallel SEPP circuit.
The SPEC-4 delivers Continuous Power Output of 150 watts per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion.
Completely Independent and Perfectly Stable Left / Right Power Supplies
The mighty power supplies are completely separated for the left and right channels. Also, each channel is provided with two 22,000uF large-capacity electrolytic capacitors and large transistors with a superior regulation. They achieve outstanding channel separation and a clear, powerful reproduced sound, in addition to the wide frequency response. There is a built-in surge killer circuit to suppress inrush currents from the power transformers and high currents which charge the electrolytic capacitors. This circuit ensures that none of the parts are affected by these adverse currents.
Protective Circuits Composed of Fast-response Relays and Electronic Circuits
Each channel is protected by a DC and over current detection relay circuit. In the event of the speaker terminal shorting due to poor connections or when DC current is generated in the output, the output circuit is immediately disengaged and the speakers and transistors are safeguarded against any possible damage. The protective circuits also function as muting circuits when the power switch is turned on and off.
Peak Level Meters with Outstanding Waveform Response
This power amplifier incorporates logarithmic compression peak meters with a wide scale (-40 -+3dB). With 8-ohm speakers, they allow the output to be read out from 0.01W to 300W. Moreover, the meters feature a fast response for peak signal indication. In addition to the peak output reading, it is easy to interpret the dynamic margin with respect to the SPEC-4’s clipping level.
Input Level Controls with dB Calibration
The SPEC-4 is equipped with input level controls with direct readout attenuation values (-dB). These can be used to continuously adjust the input levels for each channel in accordance with the rated output voltage of the preamplifier. In this way, the SPEC-4 can perform the proper gain control according to the preamplifier’s output level. The preamplifier will thus be used in the condition possible for the best S-N ratio and distortion characteristics.
Stylishly Professional Front Panel Design
Just as you would expect from a sophisticated system, the SPEC-4’s front panel is professionally designed with the large level meters in the center. Also. The front panel’s dimensions allow the model to be mounted in an EIA standard rack, just like real professional-use amplifiers.
SPECIFICATIONS
ICs………………………………........................................2
Transistors………………………………...........................61
Diodes……………………………….................................62
Power Amplifier
Circuitry………………………………Current mirror loaded differential Amplifier
3 stage darlington parallel push-pull
Direct-coupled OCL. (DC amplifier construction)
Continuous Power Output of 150 watts * per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion, or 180 watts per channel at 4 ohms from 20 Hertz to 20,000 Hertz with no more than 0.03% total harmonic distortion.
Total Harmonic Distortion (20 Hertz to 20,000 Hertz, 8 ohms)
Continuous rated power output………………………………................................0.01%
75 watts per channel power output……………………………….......................... 0.01%
1 watt per channel power output……………………………….............................0.01%
Intermodulation Distortion (50 Hertz to 7,000 Hertz = 4:1, 8 ohms)
75 watts per channel power output……………………………….........................0.005%
1 watt per channel power output………………………………........................... 0.005%
Frequency Response………………………………...............5 Hertz to 100 kHertz +0/1 dB
Input (Sensitivity / impedance)……………………………............................1V/50k ohms
Output
Speaker……………………………….................................................4 ohms to 16 ohms
Damping Factor (20 Hertz to 20,000 Hertz, 8 ohms……………………………….........100
Hum and Noise (IHF, short circuited, A network………………………………........11 5dB
Miscellaneous
Power Requirements………………………………...................................AC 120V 60 Hertz
Power Consumption………………………………..........................................760 watts (UL)
Dimensions………………………………..............................480(W) x 187(H) x 445 (D)mm
18-7/8 x 7-3/8 x 17-7/16 in.
Feb 10, 2010 | Audio Players & Recorders
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    What is the watts of this amplifier
    The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
    Mar 21, 2009 | Sony XM-1002HX Car Audio Amplifier
    Do you have instructions for wiring install on volfenhag GX8200??
    Amplifier Class AB
    Number of Channels 2
    RMS Power (4 ohms) 120 watts x 2 channels
    RMS Power (2 ohms) 200 watts x 2 channels
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 400 watts x 1 channel
    Total RMS Power Output 400 watts
    Peak Power Output 1000 watts watts x 1 channel
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.1%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    High-Pass Crossover Frequency 40 - 250 Hz
    Low-Pass Crossover Frequency 40 - 250 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio N/A
    Channel Separation N/A
    Bass Boost 0 - 18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 20A x 2
    Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Inter-M PA-2000 A Amplifier Logo
    170 people viewed this question
    Top Inter-M Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Inter-M Audio Player and Recorder Expert? Answer questions, earn points and help others
