Question about Refrigerators
Hello, I have a Maytag refrigerator Model MZD2768GE that freezes everything in the top right storage drawer. Any suggestions as to the cause and what and where to replace. Thanks, John
  • 132 Answers
The air flow to this section is probably too high. You need to close off the air flow to this side of the fridge
Posted on Mar 25, 2011
  • jrhtools Mar 25, 2011
    Thanks for the answer but it is just the top drawer that defaults to a freezing temperature. The rest of the refrigerator is fine nothing else freezes in the rest of the refrigerator. Thanks.
I need to locate the light for the crisper drawers on Maytag plus model MZD2768GE. Temp control is still working but no lighting inside drawer.
From the drawing on your model, it looks like you may have to take out the top drawer and possibly the case for the drawer. Sometimes it is behind a light shield (usually an opaque piece of plastic) although I do not see one listed for this model. The correct # for the bulb is WPA3073101 which is a 25 watt bulb but I am sure you can find an "or equivalent" that would work just fine. It could be clear or have a blue coating to make the light more natural.
Jan 28, 2018 | Maytag Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 17, 2011 | Maytag MFF2557HES Stainless Steel French...
Maytag Model MZD2768GE isn't getting cold.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Maytag Refrigerators
Why is everything in the refrigerator freezing, and, why doesn't the door & doors (side-by-side) close tight?
Sounds like your door or doors are being held open by an object inside. This is causing the cooling system to run constantly and thus freezing items in the fridge. Check that the shelf under the ice drawer is overpacked. the dispenser runs inro things on the shelf right under that storage compartment occasionally on my fridge. Hope that helps.
Jan 28, 2011 | Frigidaire FRS26H5AS Side by Side...
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Mar 19, 2009 | Maytag MBB2256GES Bottom Freezer...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Crisper drawer freezes veggies
need more info what brand model and is it a side by side or top mount ? more info will be helpful
Sep 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
