Question about Asko Dishwashers
I have noticed that my dishwasher which is totall stainless steel inside has kind of a chalky sheen to it. My glasses have "etching" and don't seem sparkly. The dishwasher is cleaning as it should. But the dullness of the stainless inside seems to be building up and nothing makes it shine.It is a model 1796
  • merleseigel Mar 24, 2011
    Have contacted manufacturer and they have a completely different set of solutions that you have not mentioned at all having to do with the drain in the bottom of the dishwasher so I am thinking the expert is not an expert.
    Brigadier General:
  • 3,513 Answers
Hi
Either you have hard water or you're seeing either calcium or lime deposits. Check the kind of water you use in the kitchen. If it is hard water you are required to use more dishwasher detergent to dissolve food residues. If it is soft water, you have to use moderate detergent, because excess detergent gives your glassware an etched-like appearance, or sometimes your glassware really becomes etched. There is a product called Dishwasher Magic that might help with this problem.
You should use jet dry for every load. If the film is soap, then the problem can be from too much soap, a poor drain or bad check valve. You should also use Rinse Aid. If you are already using it, then you may need to up the amount used. A bad check valve would allow soapy water to drain back into the tub and the rinse water would have suds that could also cause this problem.
There should never be any suds in a dishwasher. Hope you're not using liquid dish detergent or gel for the dishwasher, that's a big NO.
Instead of filling both reserves that hold the washers powder only fill the one that has the spring loaded door. Just rinse the dishes once with just water then do the regular cycle.
If you want the water to be hotter, use the pots and pans cycle. That cycle heats the water to a much higher temp.
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 24, 2011
Glasses have a white, chalky film around the top of glasses
This due in part with the government mandate to remove phosphates from detergent.
Several things can be done to improve the clean appearance of your dishes.
1. Start a wash cycle with no dishes and no soap. Once the wash cycle has stated and water is circulating,open the door and pour in one quart of white vinegar and resume the wash cycle.
2. Use a detergent named FINISH.
3. Use only the recommended amount of detergent.
4. Periodically use a product named LemiShine.
Taking these steps will improve the quality and appearance of the dishes.
On a final note: too hot water temperature can cause etching in glasses and only a lower water temp will prevent new glasses from etching.
Jul 24, 2011 | Dishwashers
White coating on glasses, silverware and door of dishwasher that is very difficult to remove (even with a stainless steel scrubber) Is there a product I should be running through the cycle (without...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Bosch shx33a05uc/14 dishes are milky with white chalky residue. Have cleaned the inside, and checked to make sure the water can exit the spray holes in the circulating parts (top and bottom). Checked...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
May 11, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
Have Whirlpool dishwasher #GU2300xtsqo. White
heatman101
Feb 16, 2010 | Whirlpool GU2300XTS 24 in Builtin...
My dishes ang glasses are cloudy *** well as the doors
The cause of the cloudiness is usually due to hard water drying on the dishes and can turn into etching (or pitting) of your dishes. If you have particularly hard water it is well worth investing in a water softener or filters. 2nd; Use plenty of rinse agent (jet dry or similar). Rinse agent gives your dishes a sheen (almost like waxing your car) and helps the dishes dry quickly and cleanly. 3rd; Clean the d/w every 1 to 3 mths. using a good cleaner. Hard water deposits can be cleaned with a little CLR. Use GLISTEN to clean your d/w. Glisten is not found in grocery stores but can be found online or at an appliance parts shop for 5-6 dollars. Please rate this post.
Dec 15, 2009 | LG LDF6920ST Stainless Steel 24 in....
Need to replace stainless steel outer door something etched in stainless will not come out on kitchenaid dishwasher
I'm not sure if they have the solution for your model but applianceart.com has faux stainless covers and they sell stainless dishwasher door panels.
Oct 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishes and glasses being etched; looking dirty; embarrassing
First of all, if you're talking about actual glass as opposed to crystal, glass can etch easily. Why? Because like crystal, there are variations in its quality. Cheap glass will etch faster with the use of an electric dishwasher compared to higher quality glass.
Did you know that the main constituent in most automatic electric dishwasher detergents is sodium hydroxide (lye) and chlorine bleach (another caustic acid)
A Bosch dishwasher has very long wash cycles, further exposing your dishes to the possibility of etching damage. You should stop using the sani-rinse cycle if there is such an option and switch to a gel format detergent as opposed to a powder. Use a rinse agent such as Jet-Dry. This should solve your etching problem.
Apr 23, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
The inside of my stainless steel dishwasher looks as if it has a white film on it. My glasses are also looking like they are etched. I haven't changed the dishwasher soap...any ideas what is causing...
are you using a rinse agent such as jet dry( you should be) and if your using tabs with rinse aid built in dont add extra rinse aid to dispensor, . water temp might be an issueperhaps some detergent has gotten into the rinse aid compartment mistakenly
Nov 04, 2008 | Dishwashers
Dishwashers Logo
191 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
