Question about Brother MFC 7300C InkJet Printer
Printer not printing black ink
My printer has been having problems printing with black ink. I changed the catridge but it is still printing the same way. the printer says to clean the printer head but i dont know how to do that
This is a problem that is always happening with these printers, to fix it, this is what you do: if you look at the cartridge it has a grip tip at the top, for you to pull it out of the printer, after you fill the cartridge put the top back on. Before you put it back in the printer, as you can see, the label on the cartridge goes around the front middle of the cartridge, it give you the model number and so forth. now turn the cartridge around, place a stripe of tape around the top of the cartridge in the same manner as the label, so that the tape is facing the toward the back of the printer. Use tape that blocks the sensor, no clear tape. The reason it does that is because no matter how much you fill the cartridge or how new it is, with this model printer, those sensors go bad and thinks every thing is empty but it only happen on the black, go figure. Try this and when you close it, it will start a long process of cleaning and your ready to go.
Posted on Nov 30, 2008
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Black colour is not printing
When you print in color is does it show black ink?
Sep 23, 2010 | Office Equipment & Supplies
Black ink won't print out. What can I do to make
check the print options befoore printing or else there may be a problem with catridge try changing it
May 23, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Will not print black ink
Please check for the catridge..
I think either the catridge is empty on INK or catridge is having problem..
So, replacing with a new catridge will solve your problem..
Jun 12, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Brother MFC 7300C InkJet Printer Logo
74 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
