Question about Whirlpool Dishwasher Handle Mount 67006113
My dishwasher will not close. It appears that the handle will not latch on the metal fitting of the washer. When I push on the handle it doesn't seem to show any resistance. On any other latch you squeeze it and something moves up and down this doesn't do anything. Is there a way of replacing the handle unit alone? thanks
  • 822 Answers
The handle is in the closed possition even when door is open,. you need to sepperate the door front from the door back........ just undo the few philips screws.....the inside of the door will pull apart... just prise the catch back to the open position...... rescrew the door....job done........
cheers
Posted on Mar 24, 2011
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
My villaware waffle model 2010 has an issue with the little metal piviting latch that allows it to turn the waffle bed. It appears that when the lid is closed, it doesn't touch the metal latch that al
the piece that seems to be not working (although you didnt show it on the video) is the top handle, and I think that if you wrap a bread twist tie around the top handle on the waffle iron side of where you grab handle, the twist tie will hit that little lever underneath when you close the lid, allowing you to spin it
Mar 09, 2013 | Kitchen Appliances - Others
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
Dishwasher will not latch
more than likely the safety clasp inside of the door panel is broken. On the dishwasher at the top where the latch fits there should be a small metal shaft extruding from the dishwasher side. This shaft, when the door is closed, pushes a bar inside the door to release the latch for closing. If this shaft is protruding from the dishwasher side and insert into the door slot then the latch mechanism in the doior itself needs replacing. If the saft is missing then it needs replacing. Get the model and serial #'s off the unit and take them to an appliance parts house for the proper part replacement.
Hope this helped you
Dave
Mar 03, 2010 | Dishwashers
Latch on door won't close.
THe door wasn't closed right.  When I pushed the corner closed and it was lined up correctly, it latched.
Dec 05, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Maytag
If the door handle appears loose, you could have a broken door latch which will prevent the dishwasher from running if the door is not able to latch properly. The latch usually has two micro switches that are pretty delicate. Not to accuse you of abusing your appliance, but if you're in the habit of slamming the dishwasher door shut, you could inadvertently break the switches in the door. The switch assembly and handle are sold separately, so you may need to purchase both. Let me know if this helps.
Jul 08, 2007 | Maytag PDB3600A Built-in Dishwasher
Whirlpool Dishwasher Handle Mount 67006113 Logo
174 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
