Cars & Trucks Logo
Posted on Mar 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The truck stalled a few days ago. It was jumped and ran fine. Yesterday it stalls again, but won't the battery won't hold a charge. It was towed to the shop and they said everything tested fine once they charged the battery. Any ideas?
Mike NHPC
Level 2:
Scholar:
  • Expert 59 Answers
  • Posted on Mar 26, 2011
Mike NHPC
Expert
Level 2:
Scholar:
Answers
59
Questions
0
Helped
47947
Points
118
Sound like might have a prooblem with the charging system. if the altenator is not charging the battery while driving then when the battery voltage gets too low (prob around 10volts) then the computers will shut down, then when jump started it gets some power back, and when the battery is charged will all work fine for a while.
does your model have the voltage gauge in the dash? should be over 12 volts when engine running, 14volts is a good charge rate. and should stay up above 12 all the time, with lights on air condon etc...
and altenators can be funny, work sometimes, and not atother times,
2004 tiburon2.0, 4CYL, 5 speed.. after changing starter a few days later the car started flashing the engine light and seemed like it was losing power, did it on the highway then was fine until dinner time...
This website www.reliable-store.com
has the largest collection of repair, service, parts manuals of any vehicle on earth. Best website I came across for manuals.. Very helpful website
Shuts off while driving but starts up
Sounds like it's not getting fuel. Check fuel pressure at the fuel rail. If low, make sure the pump is running. If the pump is running, but no pressure at the rail, check fuel, filter. Get back to us with result of these checks.
2009 Mariner Stalls in Reverse and sporadically when driving
sounds like your alt. is starting to go out and possibly a dead cell in the battery check to see if battery and alt. are working
I have a chevy s10 2.2 2003 truck and one day it ran about five miles. then stalled. it started back up idled fine but put it in gear. stalled again. had to get towed home replaced the fuel filter,truck...
When you press on the gas when the truck is running, does it rev up?
Did it die while driving down the road (foot on the accelerator) or when idle? - If so, try cranking it and get your RPMs up to 1500-2000 RPMs and put it in drive (with your other foot on the brake). See if it will continue running if you never take your foot off the gas.
Battery light comes on and off then kills my car
might be due to the battery being bad and may need replacement but if the battery is holding a charge then it might be due to a short out in some place
Battery drains and idle problems when jumped. 2002 Jeep Liberty
I would look at the fuses and fuseable links, and check the output of the alternator. If you disconnect the battery you can check the battery for a dead cell, and check the major circuits for a draw with everything turned off.
I have a 95 nissan altima, its battery went dead two days ago and we jumped it and it started fine and ran fine. Last night it started sputtering and stalling. now everytime i try to start it it runs real...
Make sure the battery and alternator is working. Get battery and alternator checked. It did not jump timing. Autozone will do it free and Walmart will check your battery. Lets try this and get back with me
3helpful
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
