Question about LG Televison & Video
Trying to support my sister some 300 miles away in functioning of LG 32LC46-ZC LCD TV(as I understand it) and requiring manual that has remote control details. Cannot find it in listings.
  • 11,361 Answers
I have LG 32LC46-ZC TV. It suddenly stopped working, no picture, no sound. The LED blinks 5 times after turning on, but nothing else. Any suggestions?
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | LG Televison & Video
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
WHAT SHOULD THE RETURN/EXIT BUTTON DO ON MY REMOTE IT ONLY SEEMS
If you look on page 48 & 49 of your LG TV’s user manual, you will see your TV remote and a description of the buttons.
Your particular remote does not have a previous channel button or function. That backwards arrow button is to return one step in an interactive application or other user interaction functions.
However, if you get the full size LG TV remote it does have a “FLASHBK” button that will go to the prior channel. Some programmable TV remotes have this feature too.
You can go to the TV store and ask to use the larger LG TV remote that has the “FLASHBK” button on your TV on display to see if your TV will perform that function.
Good luck.
May 21, 2010 | LG 42LH200C LCD TV
Sharper image jumbo remote to work with dish network
I can help you with your Sharper Image Jumbo remote control.
There are two Sharper Image Jumbo Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals. The included code lists will give you the correct codes you require.
The Jumbo Touch also has a learn function, while the standard jumbo does not.
I hope that helps.
Apr 04, 2010 | One For All URC-9910 LCD Remote Control
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Closed Captioning on LG 50 DM
i have the same problem with the closed captions... i believe to turn off the captions you have to use the remote. press the CC button repeatedly until closed captioning turns off. in my case i lost my remote so i am unable to use the method to solve the issue. Can someone please confirm that this works. so i can buy a replacement remote. Thx
Aug 14, 2008 | LG 37LP1D 37 in. LCD Television
Tvcodes
15322 is the code
Jan 30, 2008 | Televison & Video
Universal remote codes
I just tried the solution suggested by jcallahan on my Motorola DRC800 remote for my Cyberhome CH-DVD 300. The code that worked was 1023.
Aug 22, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
169 people viewed this question
