Hi in my laptop model HP G62 b50se, F2 & F3 Keys use to adjust the brightness is not working. I am using Windows 7 x64 OS. Please advice me how to fix it. I tryed by removing Quick lanch & Graphic drives to see whether it is woking as suggested in some fourms but nothing worked out. Thanks in advance
  • Bambootree May 13, 2011
    I have found the solution as a result of google search. Hence I have
    posted the link from where I found it for the benifit for all who will need it.
    The site name is -
    http://h30434.www3.hp.com/t5/Notebook-Di...
    the link to download the driver is -
    ftp://ftp.hp.com/pub/softpaq/sp49501-50000/sp49566.exe
    hope it will be useful
  • 85 Answers
Can you confirm you are holding down the FN key while pressing F2 or F3?
Posted on Mar 24, 2011
  • Bambootree Apr 06, 2011
    Yes I tried with & without fn + f2 keys. But did not work out. Is there a sequence to install the drivers. If so what is the order. could not be the reason ?
    Thanks in Advance
  • TexRyker Apr 06, 2011
    I found the manual for your computer here:
    http://h10032.www1.hp.com/ctg/Manual/c02...
    According to it the brightness is definately controlled by FN+F2 for dim and FN+F3 for brighter.
    Can you confirm if any other buttons work while using the function key? Try FN+F1 to bring up a help screen.
    My suggestion would be to attempt the following:
    If no buttons work, use this link to take you to an HP download for the quick launch button software:
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    If the buttons work and just not your brightness ones use the following link to download the most current revision of the display driver for your computer. I do not know if you have Intel or ATI as well as 32 or 64 bit so you will have to drill down to the "Driver - Graphics" section and pull down the appropriate one.
I need a computer Aires k3 user manual to download
Function Keys
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + F4 Mute
Brightness keys f2 and f3 not working after i replaced the hard disk
The brightness keys on laptops are interpreted by either the laptop hardware, or more likely, the operating system.
I would recommend going to HP's support site, http://support.hp.com, and downloading the latest chipset drivers from the site.
If you are running Windows 7 than try the Vista drivers if Win 7 is not listed as an operating system.
Jun 23, 2013 | HP Laptop Keyboard for HP Pavilion DV6000...
How do i change the funtions of the F1 to F12 keys. They are currently set up so that when i select F2 the brightness is adjusted.
I'm not sure I understand? What or Why do you want to change it? usually , when the computer is booted you use the function keys. If you reboot the laptop and immediately tap F keys you will get , say, BIOS setup, Boot Menu, Recovery program, etc. You didn't post the Make, Model of Laptop or the OS you are using?
Apr 19, 2013 | Computers & Internet
My function keys of hp probook 4420s is not working
You have to Press and Hold the FN function key at the lower left portion of your keyboard then hit the volume or brightness keys. Notice that the volume and brightness keys are the same color as the FN function key. That means you have to press and hold the FN key while you hit the volume or brightness key.
May 27, 2012 | HEWLETT-PACKARD HP ProBook 4420s Notebook...
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
Aug 23, 2011 | HP G60-120US Laptop
Loaded windows 7 ultimate and also the drivers on Hp Laptop G62. But the Brightness control buttons on Lap top are not working.Currently brightness seems to be 100%. pls suggest how to control or reduce...
try this
press f3 to increase the brightness, f2 to decrease
or,
hold fn key and press f3 to increase the brightness
fn+f2 to decrease
let me know if it works
Apr 19, 2011 | HP Computers & Internet
I have compaq presario cq42 laptop with window 7 professional operating system. my problem is that i can't adjust or decrease the screen brightness by using function key (f2 and f3). please suggest me
Now New Model Laptops Come with Fn+Multimedia Keys this Model Laptop Same Tpye. If You Change Settings Goto Bios Change "Fn Keys Behaviour" menu. OR Using Without Pressing Fn Key only Press Drictly Fn keys. Again Same Problem Please Install Quick Lanuch Button Driver (this software Working Properly Please Install .Net Frame Work First) Form Compaq Site under Software - Soultion Category (Select Proper OS) http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=4062&product=4308201&sw_lang=&#N600
Apr 08, 2011 | Compaq Presario CQ56-115DX Laptop
I can not find ATI Mobility Radeon HD 5470 Graphics switchable Driver for laptop HP G62-b50SE (Windows 7)
try visiting this link.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=4301678#N251
just choose what platform of Windows 7 you have (32bit or 64bit)
-if you don't know how to look for it:
-Click on start>type msinfo32 on the search box
-it will show you the system information window and look for system type
- if it says x86, it is a 32bit version
then expand the Drivers-Graphics item:
-you will be given 2 options to select from. and its between intel or ATI
-just select ATI and it will be compatible with your graphics card
-download the file and install.
Mar 16, 2011 | Computers & Internet
Computers & Internet Logo
943 people viewed this question
David Payne
David Payne
