Question about Brother InnovIs QC1000 Electronic Sewing Machine
I am working on a small quilt. Using the walking foot. When I turned the quilt over to check the stitches on the back I noticed they are very loose. I have never had this problem before. The back stitches have always looked as nice as the front. What is going on?
  • 2,510 Answers
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Posted on Mar 24, 2011
Can you use quilting bar with walying foot that came with si ger 9960
The info I found has no mention of the quilting bar for the Siinger 9960 walking foot. Most machine with that functionality include the quilting bar with the walking foot. There also needs to be a hole through the walking foot and a method to attach the bar to the foot which doesn't seem possible with what I located. However, you may be able to attach a bar or a guide of some sort using something like masking tape that can be used as a guide.
On a straight-line quilting tutorial I saw recently, the quilter laid down strips painter's tape to mark the lines on the quilt before doing any stitching. Then she simply stitched next to to painter's tape to get straight lines.
Feb 08, 2018 | Sewing Machines
Do I need a walking foot to stitch in the ditch using Viking freesia 415?
A walking foot would be helpful especially for quilting where there are multiple layers of fabric. The walking foot actually moves the upper layer in conjunction with the lower fabric helping to prevent wrinkles in the stitching.
For other projects, there may be other feet that could work. Your sewing machine may have other accessories, like this foot for Berninas Blindstitch foot 5
stitch in ditch Google Search
FWIW, it is very difficult to actually stitch "in the ditch" as any slight deviation will show. Usually, it is better to stitch just a bit to one side or the other.
Dec 10, 2017 | Sewing Machines
When using the walking foot how does the guide work?
Yes, you would set the guide at the distance you want the next row to appear. Set the guide to follow the previous row and then stitch with the walking foot to create the new row.
How to quilt parallel straight lines using Walking Foot Quilting Tips...
Dec 05, 2016 | Sewing Machines
I am using the walking foot for a quilting project that I am working on, however, the bottom stitching is just looping and can just be pulled away from the fabric.
Be sure you are using a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the upper thread from the beginning. Make sure the thread path is correct.
Verify the bobbin is installed and turning the correct direction in the bobbin case and that the bobbin thread is threaded through the bobbin tension mechanism.
Set the upper tension to the midway point between high & low number--this may require some adjustment for your particular machine.
Pull the bobbin thread to the top of your sewing project before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Re-test your machine on a scrap quilt sandwich (make sure the walking foot is installed correctly and that the presser foot is lowered when beginning to stitch).
Consult the owner's manual for instructions for presser foot pressure. The pressure may need to be adjusted because you are dealing with a sandwich that is thicker than regular fabric.
You may also try changing the type and size sewing machine needle you are using. Using a Top Stitch or Microtext needle will help the needle to penetrate the fabric sandwich easier. A Top Stitch needle has a larger groove to protect the thread as it pierces the fabric which helps prevent looping.
Also, verify the thread is not too small for the needle's eye.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwil1tu2mb3PAhVR6mMKHUlvB_4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Oct 02, 2016 | Sewing Machines
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
Bernina walking foot
Hm, just guessing here.
Have you checked to make sure the walking foot (u-shaped) bar is still attached to the needle bar? Are the feed dogs still in the up position and operating like they should?
Learn How to Use Sewing Machine Walking Foot
Something else that I've run across in my sewing adventures is that walking feet need periodic oiling to keep them operating. Just manipulate the walking foot with your hands and watch where there are moving joints. Then apply a small drop of good quality sewing machine oil to each joint. Work it in and then wipe off the excess so it won't stain your fabric.
May 21, 2017 | Sewing Machines
There is a loud squeaky noise when machine quilting a meandering stitch with a darning foot. The feed dogs are down, stitch width is 0, length stitch is 2.5. The machine does not squeak when using regular...
Is the darning foot aftermarket or genuine darning foot for your particular model...If it is aftermarket, it may not be the correct length. What is you model?
Jul 23, 2011 | Kenmore Sewing Machines
Stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Jul 25, 2008 | Brother CS6000i Computerized Sewing...
Brother InnovIs QC1000 Electronic Sewing Machine Logo
126 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
