Onkyo TX-DS575 Receiver Logo
Posted on Aug 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Onkyo ts595 goes into protect mode with volume increase
I have two ta595 receivers that do the same thing, the go into protect mode with volume increase past 40 on display
  • fl2789m Aug 03, 2008
    do all onkyo receivers have same problem?
Anonymous
Level 2:
  • Expert 151 Answers
  • Posted on Aug 05, 2008
Anonymous
Expert
Level 2:
Answers
151
Questions
0
Helped
61185
Points
210
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
If I increase the volume control, the sound goes out and the unit says protect
This is a piece of **** receiver. Ive had the same problem since it was brand new.
12helpful
2answers
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
2answers
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
1helpful
Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
2answers
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Onkyo TX-DS838 Issues
The problem here is that the output amplifier section has a problem. This is detected internally and the system shuts down in a "protect" mode. The output section really only kicks in when you attempt to bring up the volume. Another possibility is a problem in the "front end" where DC current is being passed to the amp section. Without takeing measurements, it is difficult to determine the exact cause. This should be a relatively stright-forward repair for a service shop and should cost about $20-$40 in parts plus the local labor charge.
Dan
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
