Question about Dell 966 All-In-One InkJet Printer
Dell AIO 966 printer prints until 99% then stops. The document shows printing in the printer window. Can't print anything else then. I try to delete the print job but just shows deleting but never does. Just bought a new desktop running windows 7 32 bit. Old system ran Vista with no print problems. I have to restart the computer to get it to print but then same problem occurs.
  • Brett Duxbury
    Brett Duxbury Aug 31, 2017
    Hi fuzz6704, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Have you installed a driver for windows 7 32-bit for dell printer ?
    Try visiting http://www.dell.com/support/home/us/en/1...
    see if it detects your o.s. of Windows 7 32 bit as it does not work on Windows 10 or Windows 8
sandrew
  • 2961 Answers
SOURCE: dell 922 aio printer
it's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
Posted on Nov 13, 2006
pagebor
  • 2785 Answers
SOURCE: Trying to install Dell Photo AIO Printer 966
please scan your pc for viruses in safe mode
Posted on Apr 07, 2008
SOURCE: Scanner won't work on Dell 924
Same thing happened to me, only different model.
First, make sure you have the right drivers (and by that I mean 32-bit or 64-bit).
Go to control panel and remove your previous installation; reboot; reload the drivers with your All-In-One UNPLUGGED until they tell you to plug it in.
That was the trick that worked for me. Good Luck.
Posted on Aug 31, 2008
dagr81
  • 59 Answers
SOURCE: Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Posted on Apr 10, 2009
  • 295 Answers
SOURCE: cant install aio esp printrt says its above 32
Contact Kodak support @ 1800 421 6699 and they will change some settings on your system. Kodak printers work only on 32 bits and 64 bits vista.
Posted on Sep 21, 2009
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Dell photo AIO 966 printer wont print red color
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 23, 2012 | Dell 966 All-In-One InkJet Printer
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
Dell Photo 966 AIO won't print after trying to download Adobe 9
You need to restore your computer to a date previous to your Adobe 9 install. Click the following:
Start-Programs-Accessories-System Tools-System Restore. Choose an available date prior to the date you installed the problematic software.
Nov 07, 2009 | Dell 966 All-In-One InkJet Printer
Printer won't finish 2-sided document
Uninstall Dell All in One Center. Download the laters drivers form http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_PHT_964&os=WW1&osl=en&catid=&impid=
it will fix your problem.
remember to choose the correct Operating System.
Jul 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
dear sir
open notepad
and copy paste
net stop spooler
net start spooler
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
Can't print document but I can scan
Try these steps:
1. Try to print a test page in the Printer Properties window. If it prints ok, then maybe Word is the problem. You may have specified some page parameter (e.g. margins, length, etc.) that was out of range.
2. Try the printer on another pc.
Mar 09, 2009 | Dell 966 All-In-One InkJet Printer
Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
123 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
