Question about Craftsman Garden
My 3 yr old put sand in my tiller's gas tank. Can it be fixed?
  • 1,498 Answers
Hi Lisa,
Hopefully it wasn't running.
You need to:
  • drain the tank
  • remove the tank
  • rinse it out (with more gas), including the hoses until no more sand is evident
  • reassemble
Compressed air can be useful in dislodging any sand remaining in the tank.
Pouring the gas through a paint filter will trap the sand so the gas can be used.
Best regards
Mike
Posted on Mar 24, 2011
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
I have a Troy Bilt Horse tiller. Upon removing the bowl on the carburator, I found no gas in it. I think the fuel line is clogged. How shoud I fix this so it will start again?
Old gas in tillers is always corroding the inside of the steel tank and the steel lines, clogging both the lines and filter and inlet at the top of the glass bowl. You can fix it by removing the tank and putting in some gas, some small stones and swishing them around to knock off all the rust scale, then replacing the steel lines with high temperature silicone fuel lines as used by radio control models for nitromethane motors. A new filter and a plastic gas tank avoid a lot of this rust clogging if you can get one to fit. If the rust has been sucked into the carb jet, use a bic pen tube with the refill removed and a small length of rubber hose to blow that out too. A good trick for small engines is to get a super tiny squirt bottle, remove the spark plug and squirt the electrode with gas. Replace and you will get about three revolutions of "firing" no matter what the condition of the carburator is.
Mar 27, 2011 | Garden
Will not start
If you have a spark plug wrench take out the spark plug look at it if it is all wet engine is flooded with gas,dry it and clean it if it is dry its not getting gas, try putting in a new spark plug. is there gas in tank , is switch on, is gas turned off, is the tank full, is the gas old and stinky? has the tiller sat for months carb may be plugged check ,engine oil level, try a little shot of engine starting fluid or gas sprayed into carb needle valve in carb may be pluged, float in carb may be stuck. tap on carburetor good luck
Jan 31, 2011 | Troy-Bilt Garden
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
8.50 Torque Rating Dual Rotating Tine Tiller: left old gas in tank and need to clean and start...
First step remove old fuel
Should be a turn off valve on bottom of fuel tank. Then go to the Carburetor were the fuel line runs to. on bottom is the float bowel. Remove the bolt in center of this bowel. drain old fuel out. Then turn on your fuel with bowel off. flushing the line. If not fuel runs out. Lightly tap the float. If still no fuel. Turn off fuel. Remove the float under the float is the needle and seat. Remove the needle if did not fall out. Clean or replace the needle. Then replace float and bowel. Turn fuel on check for leaks. remove spark plug check for spark. Should have a nice bright blue spark when you crank it. If so put a little fuel in spark plug hole. Give a pull. Or if you want dip the plug just to the end of threads in fuel. Replace plug . Should start right up.
May 18, 2010 | Craftsman 8.50 Torque Rating Dual...
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Gas in tank wont start unless put gas in carb-then
Hi, being a tiller theres a good possiblity that the line is glogged and if theres a line filter it could be plugged also. Another source of clogging is from old gas, ti can become a little varnished.
Remove the line clear it with compressed air or other source, drain the tank and if theres a line filter - replace it.
Another source could be the air filter - usually a sponge. Replace this as well or clean in a varsol bath. squeeze it out dry, then apply some oil to the input side - helps to catch dirt, etc.
USE safety precautions .
dont forget to vote
Oct 14, 2009 | Garden
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Garden Logo
105 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
