Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
MC9090 Laser beam adjustment? how do I change the beam scanning distance? I would like to shorten the scanning range from 5 feet to 2 feet.
How to calibrate a hilti pri 2 laser
There is no "calibration mode".
To check calibration set the tool on a fixed surface. turn it on. let it autolevel, then mark the wall with a pencil at a distance of 15- 20 feet. rotate the laser on its axis 90 degrees, and see if it self levels to the same line. if it does not, send it to hilti, you'll have it back in a week.
Nov 13, 2012 | Hilti Laser Level. Rotating Laser PRI 2...
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of gas.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    Mark a horizontal reference line on the vertical wall or screen.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
    Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
    On the wall or screen, locate the high intensity area of the beam pattern.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
I need to replace and then adjust the headlights on my 2000 Chrysler 300M. How do I replace the headlights, then adjust them.
Park your vehicle on level ground with the headlights near a garage door or wall. A good distance is 2-3 feet away from the wall or door. The location must be perfectly level and flat at a distance of 10 to 25 feet away from the door or wall.
Switch on the low headlight beams and mark the horizontal and vertical centerlines of each headlight beams on the wall using masking tape. This will mark the center of each beam with a +. The marking will tell you where exactly the headlight beams should be centered from a distance.
Move the vehicle back about 10 to 25 feet away from the garage door or the wall.
Keep the headlights on the low beam setting.
Use the markings you made on the wall or garage door to, check where the light shines and see if the centerlines still match up with the masking tape marks. If the centerlines of the two beams do not align with the tape marks, you can adjust one or both sides as needed.
Make the necessary adjustments with the lights still on while watching the light beams on the wall and your marks.
Turning the top adjusting screws in a clockwise direction will raise the beam while counterclockwise turn will lower it.
Turning the side adjuster screws will adjust the lights to the left or right.
Continue the adjustments until the center of the light beams are aligned with the tape marks. Then adjust the vertical alignment of both beams slightly below the marks on the wall. This will assure that the lights are tilted slightly downward so they won’t blind approaching motorist.
The will align bot lights, the high and low sine both are connected to the same headlight!!
Nov 18, 2009 | 2000 Chrysler 300M
Does anyone have a successful experience using this to scan outdoors in full daylight?
not sure if you found a solution , but I figure I''ll share mine anyways.
we had the same problem in scanning outdoor so this is what we did:
there are 2 types of MC9090 standard range and short range. the short range works batter for outdoor sine it has a wider longer beam. you will loose in distance , you will have to come closer to scan but it will work ....
let me know if you came up with something else ...
Aug 06, 2009 | Symbol MC9090 Barcode Scanner
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
DW087K
was the lens clean mine gets steamy and makes the line bigger
Oct 12, 2008 | Dewalt Self-Leveling Line Laser...
Laser beam too short
We can change the scan engine for you if you'd like - it's the only way to solve your issue. You would need a Lorax scan engine (scan up close up to approx 32feet).
Let me know if you'd like more information:
Ian
DC Solutions
ianv@dcsolutionsonline.com
Sep 24, 2008 | Zebra Symbol Technologies MC909X-G Series...
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
2,924 people viewed this question
Top Zebra Computers & Internet Experts
Mike
 steve
steve
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
