Question about Konica Minolta bizhub C250 All-In-One Laser Printer
When I print in color, there is a blue streak that runs across the page - sometimes thick and dark, other sometimes light and thin, sometimes none at all. I don't think its a toner issue. Is there a part that needs to be replaced?
  • 3,530 Answers
Welcome to Fixya
You might have a Loose toner in the system. If your drum is leaking, or you've spilled some toner inside the printer (perhaps after shaking the cartridge to get more life out of it) the excess toner may cling to the paper in streaks and get fused onto it. The cure is a good vacuum clean of the insides.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Mar 31, 2011
Whenever I print color, entire page comes out blue. I have replaced the cyan cartridge (twice) and the Laser Transfer Kit. Sometimes there are thick blue streaks in addition to the overall blue color. What...
Run the "disable cartridge check"
It will be in the Diagnostics.
Once you start the test, you can remove all the cartridges. Put the cyan in the black cartridge slot.
print a config page. If it is all blue, you have another bad cartridge. If it prints correctly(minus the other colors)...continue
Now put the magenta in the cyan cartridge slot. Print the config page again. If you have red all over the page, you have a problem with the slot itself.
Press the STOP button and then select EXIT diagnostics. Put the cartridges back where they all go and run CALIBRATION more than once.
Select/menus/down arrow/configure devce/select configure device
Down arrow/print quality/seect print quality
Down arrow/ calibrate now. Select it and wait.
Oct 25, 2010 | HP Color Laserjet 3550 Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Printing
if your problem is printer setup page in go
and select to the b & w print and ink setting
are dark print set and give your print page
problem is also
Sep 12, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Color prints have two strips of toner that will rub off.
Fixed the problem with the advice of one of your members!
Thanks
Jan 30, 2009 | Konica Minolta magicolor 2430 DL Laser...
A very thin light blue line appears on all printing jobs
Have you tried running some printer cleaning sheets through it? They are available through Office Depot, Fry's and other stores.
Also, it could be an issue with the imaging drum. I've worked on several printers which have had a similar issue and they needed the imaging drum replaced. Typically that helped.
Dec 09, 2008 | HP Color LaserJet 2600n Printer
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
