Question about Garden
Murray rider mower model #42511x4a wiring digram.
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: need parts for old murray rider mower 36 in
If you send me your email address I will send you a PDF file of the parts for your mower
m o w e r m a n 1 at h o t m a i l dot c o m
Use correct format and without the spaces
Posted on Sep 17, 2009
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
  • 6 Answers
SOURCE: The belt is too loose on my 42
Hi how old is your belt, if it is an original one or even a replacement with use go to your local repair shop and get a new belt --- take your old one so they match it up as well as your make--model---serial number of the mower. this will get you the right belt. you have a pulley that should take up the slack so I would look at the belt for streching and wear.
Posted on Oct 24, 2009
Testimonial: "Thank you."
  • 33 Answers
SOURCE: Murray select riding mower model 309000x8NA won't start?
check ground wire and posts for continuity between battery and starter, if you don't have a multimeter, remove, clean and replace all ground connectins. If that isn't it and you are sure that your battery is good and you've got good juice to the starter than the starter needs op-checked, remove it from the engine and engage it, if gear shifts out and spins rapidly you may have engine problem. Hope this helps...
Posted on Mar 29, 2010
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray rider keeps breaking primary motion belt.
try getting on Parts Tree Repair Clinic they may have a video
Aug 22, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
Need a wiring diagram for a murray rider
go on the internet at www.webcrawler.com and they have every type of diagram u want.
Apr 01, 2012 | Murray Garden
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
Need parts for old murray rider mower 36 in deck,nobody can identify model #7-36508 help please mr Rider?
Sep 17, 2009 | Garden
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need a wiring diagram for a Murry Rider, Model # 30575X8A.
Go to this web sight and enter your model number of your Murray.
http://www.murray.com/manuals/
Jul 17, 2009 | Mtd Garden
Murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Jun 02, 2009 | Computers & Internet
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
