Question about Epson Office Equipment & Supplies
I have a CX7800 printer and need to know how to clean the printer head. Can't locate my booklet of instructions..it will print about two lines and then blur the next....perhaps it is not advancing correctly? THought cleaning might help...
SOURCE: Black Ink Skipping
If you open the printer so the cartridges move to the center and lift the gray handle so you are able to pull the printer head out. Chances are when you do... you will see all the corrosion. Just clean it off and you should be good to go.
Posted on Dec 05, 2007
worldvet
  • 859 Answers
SOURCE: Canon MP500 Printer head error
Print heads for nearly all printers are rated at 2 years. You may also need to clean the tube from the resevoir at the ink supply to the cartridge and clean the working resevoir on the cartridge as well. If you are up to this challenge there is a how-to at your manufacturer's web site or you can have a tech do it. Most people, when they realize how inky you will be getting choose to have a tech do this.
It is best to use 100% denatured alcohol, from your hardware store, to clean these parts and tubing. But, you must take precautions.
DO NOT USE DENATURED ALCOHOL UNLESS YOU READ AND FOLLOW THE DIRECTIONS ON THE BACK OF THE CAN.
I'm not kidding about the precautions. I do all this stuff outside when there is a breeze in the air and then I stay up wind of my work.
If you have any questions whatsoever just feel free to comment back to me.
Regards,
Worldvet
Posted on Jun 07, 2008
  • 326 Answers
SOURCE: Cleaning printer heads
go to your start menu/settings/printers and faxes,right click on your printer and go to printer preferences and to your maintinence tab. youll be able to clean your heads from there. just to warn you might have to keep cleaning untill it runs clear and it does use a lot of your ink.
hope it helps
Posted on Jul 21, 2008
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
cg2010
  • 108 Answers
SOURCE: my new epson r230x printer is printing text and images blur
pls download the latest drivers software version of the printer that you use... then after that reinstall the old drivers software that you install previously.
Posted on Mar 02, 2010
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
Double Printing
Run the head cleaning and aligin program.
Jul 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
My pixma ip5000 printer had a paper jam and subsequently the print head seems to have gone out of alignment.It is printing in wavy lines instead of straight!! As I have 150 booklets to print by Friday I...
Hey!Go to printers and faxes on xp or printers in control panel and on the ip5000 picture,right click and go to the properties of the machine!It will open a window with tabs at the top!Click on maintenance and select print head alignment there!The machine will either do it manually or print a couple of pages where you need to select the correct value for each line!There is step by step instruction on what do to when you start doing it!Good Luck!!
Dec 08, 2010 | Canon Office Equipment & Supplies
Black striations even after cleaning
3 main things are used to determine printer quality:
1. Ink - this you have. I would consider replacing the black cartridge to eleiminate this.
2. Printer heads - these are built into the printer and could be blocked on the black section of the print head. Sometimes deep cleaning is not enough and the heads need to be replaced or the unit must be serviced.
3. Electronics. These are located at the back of the head and are vital in sending electronic pulces to the print head.. If they are damaged - a new set of heads or rather new printer.
Feb 18, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Why does my printer print blank pages?
either your print heads are dry and need cleaning, maybe several times or theres a memory issue, in which case turn it off at mains and clear the print queue then turn it back on again. let us know if this worked or if you need more
Jan 29, 2010 | Epson Stylus CX7800 All-In-One InkJet...
My photos from my printer have horizonal lines throughout...why does this happen
You need to use the head cleaning program that is in the Epson driver, Go to printers, select printer then right finger mouse select properties at bottom. In the advanced section look for head cleaning section run several times. It sometime takes a bunch of passes before it cleans up!
Nov 08, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Printing heads of my iP 90
Hi, I'm no expert, but I have this printer and I just had the same type of problem. My printed material had lines through the black ink which was nearly unreadable. After going over all of the steps that canon suggested with cleaning the print heads, I finally had to remove the print head and clean it manually. That helped alot. I also ordered a new genuine canon print head on ebay for $45.00, which is a good price for that.
Did you follow the instructions on the printer instructions for cleaning? Did you try deep cleaning? I'm not sure exactly what type of cleaning you are talking about. I can guide you through the steps, once I know what you need.
Connie
May 02, 2009 | Canon PIXMA iP90 Mobile Printer
When i print i have lots of lines in the pics!!
These lines are caused by the printheads being clogged. I recommend trying to clean them with rubbing alcohol. Epson printers have a habit of the heads drying out.
As a last resort.... you could pull the cartridges and place a drop or 2 of alcohol into the holes where the cartridges connect to the printheads. Don't put the alcohol in the cartridge themselves as this will dilure the ink.
Feb 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Epson CX7800 print head not working
it would be better if you get a new printer or the best to use is vodk and leave it over night to get rid of all the dryed ink
Aug 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
How to clean noxxles, heads, etc.
I'm not sure what you mean by lines, but I had poor print quality and even a "ker-chunk" noise in the middle of the print head travel. On these HP printers, there is a strip of plastic with very small stripes printed on it that runs through the back of the print head. This is a linear encoder that lets the printer know the position of the print head. This gets dirty and the optical "eye" can't see the transitions of the lines on the strip. Clean it with some iso-alcohol and water and you should be all set to go.
Oct 07, 2007 | HP DeskJet 840c InkJet Printer
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
