I have some channels with no audio - Televison & Video
  • 68 Answers
Vithaut brand and model I think you heave problem vith tv standard dis is in tv manu
Posted on Mar 24, 2011
Keycode for ford audio systems 3000 traffic 2 channel serial no.M127764 part no.97FP-18K876-LA...pls!!!!
Keycode for ford audio systems 3000 traffic 2 channel serial no.M016669 part no.97FP-18K876-NA...pls!!!!
Apr 06, 2011 | Car Audio & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
Under the channel it says SAP and no sound comes out on some channels,on other channels its says stero and works fine how can i fix the problem
I found this information in the manual, and perhaps it will help:
1 Switch the audio.
• Every time you press [AUDIO], the audio will
be switched as below.
MAIN : Outputs main-audio
SAP : Outputs second audio channel
MONO : Outputs mono-
Also the manual says this about SAP:
SAP
(Secondary Audio Program)
Second-audio channel delivered
separately from main-audio channel.
This audio channel is used as
an alternate in bilingual broadcasting.
Here is a link for the manual, in case you want to go over the settings. I'm thinking this is a setting problem in the menu, but it can be a physical problem with a cable line.
http://dukeelectronic.com/Manual/IWT3206.pdf
Of course it could also be a trickier problem, but check your settings, check the cable line with another TV if possible, and then contact ILO Support for help, in the event nothing fixes it.
Good luck, and hope this helps.
Dec 01, 2010 | iLO IWT3206 TV
No sound on some channels
Check to see if in the audio settings, if SAP is turned on. If so,turn it off or to the Stereo/main setting.
Oct 22, 2009 | Sanyo DP42746 42 in. Plasma Television
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
No audio
just check that the audio or this channel hasnt been set to zero and saved that way go to channel 4and select the volume up on the remote to ensure it is set to on
Jul 30, 2009 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
XL1s and 4 channel audio
Hi!
Unfortunately, Premiere Pro CS3 can only handle two channels of audio at a time when capturing. You could try capturing with Scenalyzer or another program that can handle four channels simultaneously.
Hope this helps!
Nov 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
