I cannot start any programmes, the door lock will not work, door closes properly but still not light. lots of lights have been flashing too. have unplugged it all and tried ever different programme but still no door lock.
  • Washing Mach... Master
  • 822 Answers
Hope its the door interlock......easy fix............
if its not.......circuit board may need replacing.......sorry..
cheers
Posted on Mar 24, 2011
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
My dryer drct70w will not power up have check on/off switch and fuse they are working ok none of the lights illumiate
Machine does not switch on or the programme does not start. Machine is not activated when set.
* It might have not been plugged in.
* The loading door may be ajar.
* Programme might have not been set or the «Start/Pause/Cancel» button might have not been pressed.
* «Childproof lock» might have been activated.
* The condenser cover on the models with a condenser might not be closed securely.
* Make sure that the machine is plugged in.
* Make sure that the loading door is properly closed.
* Make sure that the programme has been set and it is not in "Pause" mode.
* Deactivate the childproof lock.
* Make sure that the condenser cover and the red lock is closed securely.
A Call an authorised service agent if the problem persists.
Dec 02, 2014 | Dryers
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
Start light flashing. Unable to adjust
water not entering machine start light flashing and alarm sounds
Nov 13, 2010 | Tecnik TDW2677 Built-in Dishwasher
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Jul 31, 2008 | Washing Machines
Hardbody 2002
get into the truck and close and lock the door. place the key in and out of the ignition cylinder about six times(not too fast or slow) until you see the hazzard lights flash twice. then turn the key to the acc. position and then press the lock button on the remote(if lock doesn't work you can push another button on the remote). if the hazzard lights flash it is now programmed. then turn the key to off and pull it out and then unlock the door and open and close it. now test the remote.
Jul 21, 2008 | 1990 Nissan Hardbody King Cab
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
