Question about Vacuums
Help me with mobile phones that support skype messenger in india.
How to Fix 'Skype has Stopped Working' Error?
Get a FREE copy of REVO UNINSTALLER here:
Revo Uninstaller Remove unwanted programs and traces easily
UNINSTALL SKYPE.
Then go here:
Microsoft com site search results
"Support : skype uninstall tool"
Apr 04, 2018 | Vacuums
I got panasonic mixie in India. i was grinding rice for dosa and after 3 rounds it stopped working. base connected to motor is not turning. please help me with this. Thanks in advance.
This is probably due to overloading. Press the small red push button at the base of the mixie (not the jar). Then it should work as normal. Try loading lesser and use ice cubes instead of water to grind batter to prevent overheating. Hope this helps!!!!
Aug 17, 2011 | Vacuums
I want to remove my restriction code of Nokia 3110c from t-mobile how can I remove it please help
If your mobile is restricted to particularnetwork you need to unlock your mobile , Unlocking by codes is the safest &best method,you can try here http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ to getunlock codes for your mobile and get it unlocked safely..
Jun 01, 2011 | Vacuums
Hi i got nokia 5300 mobile from vodfone but i have orange and i want to use it in my mobile..but if i insert orange it says phone is restricted...help me please...
Hi,you have to unlock your mobile imorder to use orange in your mobile..try here to get unlock code for your mobile from here http://www.unlocking4u.com/nokia-5300/rs6wp9/ and get it unlocked safely..
Apr 04, 2011 | Vacuums
Phone unlock code
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
Do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software...
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If you are talking about the security lock code to enter into the phone then once it is lost nothing can be done except flashing the mobile . Because if anybody can give the security code created then who ever who steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if you forget the security lock you have to reset the mobile memory by flashing the mobile at an authorized service center.So while flashing the mobile all the data in the mobile memory will be lost and you can again start using the mobile.
Mar 27, 2011 | Vacuums
My phone is gfive u 909 . iforgot my phone lock code. it is asking the code when i switch on the mobile . please help me.........
my phone is gfive u 909 . iforgot my phone lock code. it is asking the code when i switch on the mobile . please help me......... my email address subhashmishra2010@gamil.com
Feb 09, 2011 | Vacuums
Phone is purchased from england and now I m in India but its not working here and asking subsidy pass
It will not work, the phone systems are probably not compatable.
Jan 16, 2011 | Vacuums
MY ASUS PHONE, Touch screen is broken.Pl tell me some ASUS service center in Ghaziabad,U.P.,India
Go to the site listed below for addresses to the nearest service centres to you. Please do not forget to rate the answer I give you.
http://asuspartner.in/BranchesAndFacilities/aboutasus3.htm
Dec 26, 2010 | Vacuums
Dear sir, i needs a solution for chinese nokia 6300 mobile's white screen problems so help me how i can solve this problems please.......... fast help me sir. thank you
Remove the memory card and battery replace batterry after 30 minutes to hard reset. If the phone boots up then check card for errors, virus, delete, format as required and reset.
If this wont solve , you will need help fromNokia care to reinstall the software.
Sep 30, 2010 | Vacuums
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
