Question about Kodak EasyShare M320 Digital Camera
Lense wont open - Kodak EasyShare M320 Digital Camera
  • 2,574 Answers
It was caused by low batteries or bad connections between the camera and the batteries.Most cameras will reset or restore to original settings if batteries are removed for at least one minute. Clean, charge, and insert batteries again then restart the camera. Electrical contacts in the camera and on the batteries must be cleaned properly.
Posted on Mar 24, 2011
My camera wont open
same as kakima, in what way wont it open, if you mean lens wont come of, then press lens button and turn clockwise to take of.
Apr 03, 2014 | Cameras
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
The lense is in the open position and will not turn on or off.
kodak is known for lense isues. Dirt gets loged in the lense real easily.. just try and get it out. blow in the lense... tap it upside down gently... wiggle it around gently.. it worked for mine. I thought i was going to have to get a new camera but i tried all these things and then it turned on. also.. if it wont turn off remove the battery
Apr 17, 2010 | Kodak EasyShare One Digital Camera
My lense wont open after a fall i want to replace the entire lense module when can i get it
1.) GO to the place where you purchased your Fuji FinePix. They will probably sell you a new lense (or camera). I dought that they wont.
2) if that doesnt work, then you can go to a repair shop and get it fixed.
#) Thank you, and have a nice day
Oct 13, 2009 | Fuji FinePix F20 Digital Camera
I dropped my camera and now when turning camera on the shutter comes out for about 2 seconds then it beeps and then it goes back in, I can view photos but not take any.
The most of cases problems is your camera lense wont come out properly. it's appear to be a electronic problem but it's defenetly a mechanical problem. do do as i say. turn on your camera and after lense came out quickly remove the battery. after that camera lense move out shake it well. shake your camera well. your target should be remove if ther any blocking thing the way your camera lense come out. if this way wont work you have to open your camera and check your mechanism. some time it can be broken lense.
Jul 09, 2009 | Casio Exilim EX-S880 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
2006 Honda Accord Dome Light
lok real carefull at the lense there will bee two little slots in the lense between the cover and the trim you can use a pockett screw driver or a butter knife and pry open the lense away from the trim it well be a little stuborn but dont worry you wont crack the lense
Nov 18, 2008 | 2006 Honda Accord
Lense wont open
Firmware fault Tell Olympus Tech Support
May 04, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Kodak EasyShare M320 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
