Question about PSC QS6000 Plus Handheld
I have a Dell Optiplex 320 running Windows XP SP2. If I plug in the QS6000 Plus USB Scanner it hangs while booting up. If I wait until Windows has started and plug in the scanner everything works. I have unplugged the keyboard and left the scanner plugged in and again the OS hangs. If I plug in the scanner after starting the computer and I restart the computer, everything works. What is wrong?
  • 107 Answers
Most probably you have only one slot of RAM (a 256MB) if so you will need to upgrade it to more such as 1GB of RAM, the problem seems to be that the OS needs more Random Access Memory to connect with your Scanners drivers and make them part of the system such that you can be able to use it when you log in this becomes a problem as with limited Memory the OS fails to read the drivers and linking the scanner gets interrupted thus hanging on startup as it has other processes using the RAM at the same time and thus sharing it with the Scanner drivers and configurations. After other programs and processes have finished to run and minimal background processes are left after logon then this means more RAM is available so the Scanner can work easily when plugged at this point.
Posted on May 02, 2011
My Dell optiplex 320 won't boot windows XP. It starts set up then asks for sp 2 installation disc. I don't have any of the discs that go to that computer
https://support.microsoft.com/en-us/kb/900910 .go to this link and it will tell you all about why you need sp2 cd..
mind you if you dont have the windows xp disk one and its not loading its windows at start up you may have a bit of trouble getting it to start in windows.more so who ever you got it of was in the middle of putting a new set of windows on it but did not let it fully load its windows then you will need to get a windows xp disk and put a new set on your self.
Nov 21, 2016 | Dell Computers & Internet
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
My dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Feb 17, 2009 | Dell OptiPlex GX200 PC Desktop
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
Installation problems
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Nov 29, 2007 | Mustek A3 USB Flatbed Scanner
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
PSC QS6000 Plus Handheld Logo
112 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Sardar Yasir
Sardar Yasir
Level 1 Expert
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
