Question about Maytag MDB7100AWB Dishwasher
Poor wash performance - spray action not energetic enough
After 7 years of use, our Maytag MDB7130 is showing poor wash performance because the water is NOT being sprayed energetically enough. I cleaned screens and that certainly restored performance for a while but now I need to clean screens more and more often. Now only 2 days since screens cleaned and washing performance is just abysmal. Plenty of nice hot water in tub, just doesn't splash as hard as before, e.g. the soap in the dispenser isn't even getting exposed to the water! Going to pull arm and filter cover off and clean again but I may have to disassemble even farther. Any ideas?
  • Bob Groh Aug 27, 2008
    Found the solution - a much more complete cleaning! I discovered that I could disassemble much more of the innards including the screen (which just pulls up and out), and the arm that mushs the garbage. Also yanked down the arm at the top of the tub (comes out with a bit of extra force - who knew!). Thoughly cleaned the screen in sink using toothbrush. Throughly cleaned the slots in the inner arm (they were virtually totally plugged). Cleaned both spray arms with a long thin needle. It is working great! Can supply more details.
If you have hard water, I am told that Tang works well (citric acid).
Posted on Sep 10, 2008
  • 3 Answers
Same problem here! There's no obvious way to dissassemble, and on my model, MDB7100, I don't even have ability to clean the screens better than simply wiping them with my finger.
Am now considering strong cleansers, acids, and failing that, dynamite...
Posted on Aug 27, 2008
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
Maytag Centennial washing machine won't drain now won't feel any water in
These machines are poor quality for a Maytag. If its more than 8 years old, replace it. The repairs are greater the value of the machine
Aug 03, 2014 | Washing Machines
Poor rinse on maytag model mdb8600awq
Did you check the screen at the bottom of your dishwasher? It may be clogged with food particles. If these particles aren't small enough to get flushed down they will just recycle through the water.
I always make it a practice to rinse off my dishes before I place them in the DW. Some newer models have better drainage systems, but perhaps yours is an older model.
Dec 22, 2012 | Maytag Dishwashers
Spray arms not rotating
Check pump in the dish washer. Clean and check!
Apr 28, 2010 | Neff S5946 Built-In Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Poor Cleaning and getting worse
A common cause of poor washing is improper loading—dishes block or impede the spray arms or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with washing, the problem may not be your dishwasher. Your home's water pressure may be too low, the water may be too hard, you may not be using the right amount of detergent, or the water temperature may not be hot enough
Apr 29, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Maytag MDB7100AWB Dishwasher Logo
370 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
