Question about LG MZ-42PZ14 42 in. Plasma Television
Lg tv shows a no signal sign and does'nt react to remote control
  • 68 Answers
5 volts linea is bad
Posted on Mar 24, 2011
My lg remote won't work
The remote itself can be tested by almost any TV shop to see if working or not---pointed at a tester and any or all buttons pushed to see if remote is working or not.
Many digital cameras will in a very dark room react in same way with a faint flash on the camera display when buttons are pressed.
If remote tests good the set does have a remote receiver built into the front of it, that would be suspect if the remote checks good.
Oct 15, 2012 | LG Mkj40653801 Factory Original Remote...
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
My lg 32lg2000tv shows no audio or vidoe
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 23, 2012 | Televison & Video
Toshiba 40rv52u remote control
If just using one remote to try have it tested----many digital cameras in a dim light will react with a flash on the display screen when remote is pointed at them and buttons pressed.
Also try putting remote against remote receiver lens on front of set--if it reacts close up---the remote receiver in the set is bad---can be same if no reaction at all.
Either the remote or the receiver---one or the other.
A last thought here is some sets (read owner manual) have a feature to lock out the remote which can be engaged by accident.
May 15, 2012 | Toshiba 40RV52U TV
My lg tv displays V3.10.1 an does not respond to manual or remote control
It is showing the software/firmware version--seems you may have by accident gotten into a place you should not be in---best answer is get LG on the phone with model number and the V3 information---I doubt anyone here will resolve this issue instantly.
Apr 20, 2012 | Televison & Video
Just bought an ANTSIG 4 in 1 universal remote control and cant find the code to operate an LG vcr.. can you help ?
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. I have only tried this with an LG TV. Hopefully it helps you out. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working. Maybe you'd need to press something else instead of TV for a VCR? But the trick is to be about 1mm away from the signal receiver. I literally put it in front of the red light of the tv.
Feb 03, 2011 | Televison & Video
Lookin for code
Try the Auto Search. It is explained in the user manual.
Text straight from the manual:
Set Up By Auto Search
A.) Power on the device you want to control.
B.) Press and hold [SET] key, in the meantime, press and hold the device key [ex. TV1] for more than 3 seconds and then release them, the auto search begins. The remote control enters into Auto Search, LED flashing, and remote control transmits power signal every 2.0 second automatically.
C.) See if the device reacts or not, once the device reacts, press any key (except the SET key) to stop the Auto Search.
May 24, 2009 | Durabrand DWT1304 13" TV
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
LG remote control
i have a lg tv that did the same,lg came out and changed the mother board.worked for 3weeks and has started again.im lucky ive been offered a full refund. as i only had it 8weeks. this is a known fault to lg. if i were you i would call lg and kick up a fuss.try and get your money back or a free motherboard. as for me i wouldnt touch an lg item again. hope this has been some help
May 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG MZ-42PZ14 42 in. Plasma Television Logo
