Question about Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony TV model # kdf-E50a10, there is a shadow in the middle of the screen . I can still see the picture, but there seems to be a cloud in the center of the screen. How can I fix
  • 643 Answers
Problem is called the optical block assembly. repair runs around 1200 dollars. if you call sony with your model# and serial # they may offer you a new tv at a discounted price. 1800-282-2848
Posted on Mar 24, 2011
Testimonial: "Thanks "
SOURCE:
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
Hello! I have a problem with my kdf-e50a10 sony wega. When i watch TV i see a yellowish vertical line right in the middle of my tv is like 10 inches wide, all the way from the top to the bottom of the...
This is caused by a failure of the optical block of your TV. The only way to fix the issue is to replace the whole optical block which is very expensive ($1000+) and time consuming (need to take whole TV apart to replace the part).
The optical block in your model had inherent issues and there is currently a class action lawsuit pending against Sony for this issue. Up to date information reguarding the lawsuit can be found here: http://www.sonya20tvclassaction.com/main/home.sfx
Oct 07, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
The picture has a yellow shadow and green tint
needs an optical block, contact sony and ask about the "optical block'' program. you should be able to get it for free. Julio
Aug 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
"my kdf e50a10 has a green screen Is this is a lamp problem or an
Green picture is caused by the light engine (the projection part of tv) failing and has to be replaced. Sony has extended the warranty on some models so you might be in lick. Contact them with model and serial number they can help setup repair if you qualify. If it is not covered it can cost between $1000-2000 to fix, which is way too much.
Rustym62
http://www.the-tv-dude.typepad.com
Mar 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Green Blurr
hi.... its hight time that u have a bad optical block in ur television.. The block has a 2 year warrnty but you will have to pay labor to have a technical change it.. try to get a new optical block and it will do it for u..
thank u rate me!!
Feb 10, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony KDF-E50A10 50 inch LCD TV
Did you get this resolved yet? Let me know. Jay
Oct 03, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
your optical block requiers replacing.not a cheap job.around £600.00
Sony KDF-E50A10 50 in. LCD HDTV Logo
560 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
