Question about LG Televison & Video
Lg 37lc55 tv picture is ghosting amounst other things took it to a repair man he says lg have to fix it due to corrupt data....is there anyway of me doing this by updating the software...current version is 4.1.1
SOURCE: LG plasma tv
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
romsky79
  • 822 Answers
SOURCE: The picture is gone, black screen only
check inverter and power supply.
Posted on May 30, 2009
dave1645
  • 834 Answers
SOURCE: Ihave had problems switching my thomson 30lcdb03
thomsom or RCA tv;s are known for power supply issues
check yours for puffed up can like devices on both main and power board if you find one the value is on the side replace it and you will have fixed it won't hurt to try
Posted on Nov 20, 2009
brownline45
  • 310 Answers
SOURCE: HI, MY LG 37LC55 HAS THE ON LIGHT FLASHING GREEN.
maybe your tv has a defect,go to the LG service center ask a technician to fix your tv
Posted on Jun 19, 2010
  • 144 Answers
SOURCE: Hi, I have a
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Posted on Nov 11, 2010
Screen distortion
Its due to your screen colour pixels problem! mostly its done due to the presense of magnetic things around the TV. But as far as i know you cannot repair by your own! it needs some expertise*
Dec 08, 2007 | RCA HD56W66 56" HDTV
Hello. I contacted you earlier, your email went to my spam. I missed it and cancelled . Sorry. The problem. I have is a ghosting picture of a program I watched earlier. The problem comes and gos....
Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Jan 25, 2012 | LG 50PC1DRA 50 in. Plasma Television
HI, MY LG 37LC55 HAS THE ON LIGHT FLASHING GREEN. ALSO THERE IS NO PICTURE. CAN ANYONE HELP?
Jun 19, 2010 | LG 42PC5D Television
Ihave had problems switching my thomson 30lcdb03 tv on for about 3/4 months. I have had a completely green screen, balnk screen with sound only, and a white ghosting on the picture. Now the tv will not...
Nov 20, 2009 | Thomson 30LCDB03B 30 in. HDTV
Picture freezing and discoloration!
This is due to a buffer issue, to be more precise, the signal that comprises the picture and the audio are streams of data that go into a buffer and then into the processor. When the signal is at the proper level and the stream is not corrupted the image on the screen is ok, but when the signal is not at the proper level and the data stream becomes corrupted the pre-processor throws parts of the data away, and feeds the rest into the buffer wich goes into the main processor. Herein lays your problem if the main processor rejects the data or the buffer runs out of data due to the preprocessor throwing away data also you will get the screen freezing and pixelation (the square blocked dsicoloration you are talking about).
Now that we know what the problem is how do you fix it. First of all I would suggest following the owners manual procedure on downloading the software patch/upgrade for this TV. Then after using the software patch/upgrade, see if this helps. If not then you have a hardware issue. I have seen this problem caused by dried out or damaged filter capacitors (thes capacitors filter the DC voltage and if they go bad ther could be a relationship between the "dirty voltage" and the corruption of your data.
I any event I would suggest that you have a qualified TV technician repir this TV for to avoid any damage that may result from a missed procedure or lack of TV repair knowledge.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 27, 2009 | LG 37LC7D 37 in. LCD HDTV
A printer repair man fixed our deve error. took
maybe the printer repair man guarantees his work? i would be telling him that sijnce he fixed it this problem occured.
Jun 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Thanks,
Dan
Feb 13, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
Televison & Video Logo
89 people viewed this question
Computer Repairing
Computer Repairing
