Lexmark x1240; on/off button continually blinking; went to preferences and did everything instructed to do, nothing worked
  • 1 more comment
  • dino758 Mar 24, 2011
    I have followed your instructions twice AND THE ON/OFF BOTTON IS STILL BLINKING THE SAME.......
    PROBLEM NOT SOLVED..........HELP
    I followed the instructions from the previous expert and it did not fix my problem.
    My lexmark x1240 printer on/off button is blinking continouslly and will not print. I have used the troubleshooting methods and they did not work. Can you HELP??
  • dino758 Mar 27, 2011
    on/off light no longer blinking!! I found that my color cartridge was damaged, replaced it with a new and that solved my problem...
    Thanks.....
    Genius:
  • 1,570 Answers
Hi
Did you printer jammed when printing? If yes, check for paper jams in the paper tray, from the cartridge compartment and from the access door (back of the printer if accessible or can be open) and clean the paper jammed.
If the problem is regard ink cartridge, remove and rub the ink head into a plain paper until ink flows. Then try to print again.
If ink cartridge error problem, try to install and reinstall it again.
Try also hard reset the printer.
1.Shut down the computer.
2.Open the top cover of the printer and remove the print cartridges.
3.Close the top cover of the printer.
4.Press the power button on the printer to turn the printer off.
5.Disconnect the communications, (USB or Parallel), cable from the back of the printer.
6.Disconnect the power cord from the back of the printer for one minute.
7.Reconnect the communications cable to the printer.
8.Reconnect the power cable to the printer.
9.Press the printer power button to turn the printer on.
10.Open the top cover and reinsert the print cartridges.
11.Close the top cover and print the calibration page.
12.Restart the computer.
Please post more comment if you need more help. Regards.
Posted on Mar 24, 2011
  • Benjamin Jr Singson Mar 30, 2011
    Please try this solution.
    Remove the USB cable into the printer and leave the printer on.
    Remove all the cartridges.
    Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
    Disconnect the power cable and from the power source supply. Wait for a couple of minutes.
    Reconnect power cord and turn on the printer.
    Return all the ink cartridges and close the door. Wait for the calibration process.
    Print the test page to check if it working.
    Reconnect the USB cable and try to print again.
    Post comment if you need more help. Regards
    President:
  • 2,653 Answers
Disconnect the unit from the computer, remove the power as well. Let it sit for 1 minute then power the unit back on. Don't connect to the computer. Does it still blink the same?
  • RescueTechLA
    RescueTechLA Mar 24, 2011
    Try this:
    1. Turn the printer's "Power" off
    2. Press and hold the "Paper Feed" (gray) button.
    3. While holding the "Paper Feed" button down turn the "Power" button on and hold both buttons until the power light comes on 5-7 seconds.
    4. Release both "Power" and "Paper Feed" buttons.
    5. The printer should feed a sheet of paper in and print a test page.
    The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously).
  • RescueTechLA
    Try this version instead.
    1. Power the printer off.
    2. Press and hold the "Paper Feed" button.
    3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
    4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
    5. Power the printer off, as this test is continuous.
How to make a copy using a computer with lexmark x1240
Make sure the Lexmark software is installed on your computer. You can download the Lexmark X1240 printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For a more comprehensive instructions on how to make a Copy to your printer using a computer, please refer to the Lexmark X1240 User's Guide.
Jul 06, 2011 | Lexmark X1240 All-In-One InkJet Printer
My pc wont install the mfg software crashes at end of install
Try the Lexmark X1240 drivers from the Lexmark website at http://bit.ly/9ZwP3q. Choose the driver compatible with your computer's operating system. Download, execute the file and follow the instructions in the software. If the problem continues, there may be something in your computer that's preventing the software from running properly. Please contact Lexmark technical support for further troubleshooting. Thanks.
Sep 30, 2010 | Lexmark X1240 All-In-One InkJet Printer
I have a X6650 lexmark all-in-one printer and i need to change the language. how can i do it . ihave tried everything that i know and nothing works please help me thank you l
You need to reset the printer to default settings (note: this does not affect wireless settings). Turn off the printer by pressing the power button for four seconds. Press and hold Start (green circle) and the Cancel (red X) buttons on the operator panel, then press power button to turn the printer on. Continue holding down Start and the Cancel button until Language Selection appears. Choose your preferred language. Set the country, date and time and the fax settings if you have one. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Flashing power button and doesnt stop
One of a few things. It can be the ink is too low, paper jam, or the chip board went bad in it due to dust, dirt, or just lousey building :)
Jan 06, 2010 | Lexmark X1240 All-In-One InkJet Printer
Im tring to intall my lexmark x1240 printer i went to the site and dl the driver and still wont work tell me can find it so what do i do
I had my pc reformated and do not have the install disc for my printer..lexmark X1240 I went to the download site and they want me to buy a driver that cost as much as a new printer costs...help me
Nov 26, 2008 | Lexmark X1240 All-In-One InkJet Printer
I can't get my printer to work, and I can't find the disk to reload the info. It is a lexmark x1240. thanks Misty
Your driver can be downloaded here, directly from Lexmark:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1240
Choose your operating system from the list, and download.
Be sure to unplug the printer from the PC before installing the software. Only plug it in once the on-screen instructions tell you to do so.
Apr 13, 2008 | Office Equipment & Supplies
66 people viewed this question
k24674
jasbo
jasbo
