Question about Epson Stylus 1400 InkJet Photo Printer
My Epson 1400 printer starts out printing the first couple of pages good, but then it starts moving the print area over on each page until it runs it off the page. Please help.
  • 3 Answers
Try to put the paper in to the printer one by one.
Posted on Sep 04, 2011
Epson troubleshooting
What you have I highly suspect is a highly clogged print head. Even if you continue to clean your print head you will use ink to do it, so you will be spending a lot of ink and trust me it wont fix the problem. I have two epsons 1400 and had the same problem and used cleaning solutions but at the end it helped but did not fix the problem.
So at the I decided to use a cleaning solution that comes in cartridges specific for your printer. Its name is UNBLOCK UNCLOG CARTRIDGES, Its seller in E-bay is Sy1507. It worked. but for example it took me around three days. I printed a job and let it sit for a couple of hours until the page printed all white. After the page prints all white then you change the cartridges with ink and do a test print and if prints right, do a print job, You will be amazed at the results. Good Luck.
Jul 25, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Printing items too long
I would reinstall the printer drivers
Nov 06, 2017 | Trendware TRENDnet TE100-P1U Print Server
Epson 1400 will not use double sided paper
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Mar 04, 2012 | Epson Stylus 1400 InkJet Photo Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Can't clear the buffer
Run a Printer Check: You can run a printer check to determine whether a problem comes from the printer itself or some other source. Before you run a printer check, make sure the CD/DVD tray is not inserted in the printer. 1. Turn off both the printer and computer. Then disconnect the USB cable from the printer. 2. Make sure letter-size plain paper is loaded in the printer. 3. Press the probsolv.5.1.25.jpg paper and probsolv.5.1.26.jpg power buttons together to turn on the printer. Continue holding down the probsolv.5.1.27.jpg paper button until the green probsolv.5.1.28.jpg power light starts to flash, then release it. A test page prints showing the printer’s ROM version number and a nozzle check pattern. (If the pattern has gaps, you need to clean the print head.) 4. Turn off the printer after it prints the test page. Then reconnect the cable and turn on your printer and computer. If the test page prints, the problem probably lies in your software settings, the cable, or your computer. It’s also possible that your software may not be installed correctly. Follow the instructions in Uninstalling Printer Software to uninstall and reinstall your software. If the test page doesn’t print, you may have a problem with your printer. Try the suggestions in Problems and Solutions. If nothing works, contact Epson as described in Where to Get Help. Problems and Solutions
See page 63 in the manual:
http://files.support.epson.com/pdf/pho140/pho140ug.pdf
Also, in the solving problems section of this reference guide:
http://files.support.epson.com/htmldocs/pho140/pho140rf/wwhelp/wwhimpl/js/html/wwhelp.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 08, 2009 | Epson Stylus 1400 InkJet Photo Printer
EPSON 1400 PRINT HEAD
Printheads on that EPSON...as almost all Epson brand printers are IMPOSIBLE to change. Are made for waste containers! It's trgough. If you can change head on that, maybe in a bit less than 200 hours! It's NOT a joke! Better, i nought a K8400 HP large format...It's 4 seconds to change heads. Also, they are cheap price and LAST very very long...but NEVER let any inkjet printer without printing all 4 colors for a minimum of 1 page in 3 weeks. Heads would dry. If you care you'll print with the K8400 for about 100,000 pages.
Nov 30, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson photo 1400
seth, did u figure this out since last month? I am looking for the same, a print server that works with the epson 1400. is it too new on the market for any print server to know whether it works?
Oct 26, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Epson Stylus  1400 InkJet Photo Printer Logo
494 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
