Question about Troy Bilt 5.5hp Self Propelled Mower
What do I need to do to remove the blade adapter assembly for replacement?
    Novelist:
  • 111 Answers
You can remove it with a flywheel puller. I would use the one that has the flat hooks at the bottom of the puller. I would also use the blade bolt to push against with the flywheel puller. If you hook the flywheel puller onto the crankshaft there is a possibility that you could damage the threads for the blade bolt.
I hope this helps you out.
Posted on Apr 05, 2011
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Honda lawnmower blade broken at shaft
How To Remove Lawnmower Blade Adapter
If it's the blade that is broken, remove the two bolts that hold the blade onto the blade adapter. If the blade adapter is broken, it needs to be taken off the engine shaft. The Link shows a video on how to remove a blade adapter. Hope this helps......
May 01, 2014 | Garden
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
How to remove fan on a 5.2L engine
Hi, 5.2L Engines
  1. Disconnect the negative battery cable.
  2. The viscous fan drive and blade assembly is threaded into the water pump hub shaft. Remove the fan drive and blade assembly from the water pump by turning the mounting nut counterclockwise as viewed from the front while securing the water pump pulley. Do not remove or unbolt the fan drive and blade at this time.
Fig. : Fan blade and viscous drive (click for zoom)
The threads on the viscous fan drive are right hand threaded.
  1. Remove the 2 fan shroud-to-upper crossmember nuts.
  2. Remove the fan drive, blade and shroud as an assembly.
WARNING Do not place the viscous fan drive in a horizontal position. If stored horizontally, silicone fluid in the viscous fan drive could drain into its bearing assembly and the assembly would have to be replaced.
CAUTION Do not remove the water pump pulley-to-water pump bolts. The pulley is under spring tension.
  1. Remove the 4 bolts securing the fan blade assembly to the viscous fan drive.
To install:
  1. Install the fan blade on the viscous drive. Install the bolts and tighten them to 17 ft. lbs. (23 Nm).
  2. Position the fan shroud, viscous fan and blade into the engine compartment as an assembly.
  3. Position the fan shroud to the radiator. Insert the lower slots of the shroud into the crossmember. Install the upper attaching nuts.
Ensure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
  1. Install the fan drive and blade assembly to the water pump shaft and tighten the nut.
Ensure there is at least 1 inch (25mm) between the tips of the fan blades and shroud.
  1. Connect the negative battery cable.
Take care
Aug 04, 2010 | 1993 Jeep Grand Cherokee
How to remove fan
Congrats, I have one 1993 GC Limited and its a nice SUV...
5.2L Engines
To install:
Also, its possible that you are interesting in check the Service Manual ZJ-Secc-7-Cooling-System
Hope helps with this (remember comment and rated this).
Aug 03, 2010 | 1995 Jeep Grand Cherokee
The wiper motor on my 1983 Ford Ranger still works but the wipers no longer move. I think there is a failure of the mechanical linkage. Where do I go to find repair parts?
why do you think the motor still works if the wipers don't move? Can you hear the motor run or can you see a little movement when you turn the switch on?
What happens when you activate the washers?
go to a salvage yard that allows you to remove the parts yourself. Then you can see how the motor and linkage assembly comes out.
don't have 1983 info, but here is 1994:
Section 01-16A: Wiper and Washer System, Ranger/Explorer 1994 Ranger and Explorer Vehicles Workshop Manual
DESCRIPTION AND OPERATION Windshield Wiper System, Ranger/Explorer The windshield wipers are actuated by a permanent magnet, rotary-type electric windshield wiper motor (17504) . The two windshield wiper pivot arms (17526) and windshield wiper blades (17528) are mounted on a pivot shaft, one at each side of the windshield. The windshield wiper mounting arm and pivot shaft (17566) are connected to the motor by windshield wiper adapter and connecting arm clip (17531) . Ranger and Explorer vehicles are equipped with an interval wiper and washer (IWW) system featuring a lever-type turn signal and windshield wiper switch (13K359) mounted on the steering column. The IWW windshield wiper governor (17C476) uses a relay contact to control current to the windshield wiper motor . The governor electronic circuitry controls the contact to supply current to windshield wiper motor . A rear wiper/washer system is available on Explorer vehicles. The rear window wiper system consists of a windshield wiper motor mounted inside the liftgate (40010) , an articulating windshield wiper pivot arm and windshield wiper blade , a windshield wiper/washer switch (17A553) and an inline circuit breaker. The front electric windshield washer system consists of a control switch, integral with the turn signal, a windshield washer reservoir (17618) and windshield wiper motor and the necessary windshield washer hoses (17A605) , windshield washer nozzle jet and brackets (17603) and attaching parts.
Pivot Shafts and Linkage Removal and Installation
NOTE: The left and right pivot and windshield wiper adapter and connecting arm clip assemblies are serviced separately.
  1. Perform Steps 1 through 9 of Windshield Wiper Motor Removal as described in this section.
  1. If servicing left windshield wiper adapter and connecting arm clip , remove left windshield wiper mounting arm and pivot shaft and windshield wiper blade assembly.
  1. Remove left windshield wiper adapter and connecting arm clip access cover.
  1. Remove left pivot nut, lower windshield wiper adapter and connecting arm clip and slide it out through left access opening. For installation, follow removal procedures in reverse order. Tighten nut to 10-13 Nm (7-10 ft-lb). Make sure the clip is fully seated in the windshield wiper adapter and connecting arm clip . Do not try to install clip with windshield wiper adapter and connecting arm clip on motor crank pin.
Windshield Wiper Motor Windshield wiper motor are not serviceable. If worn or damaged, the windshield wiper motor must be replaced as an assembly. Removal
  1. Cycle windshield wiper blades until in straight-up position and turn ignition switch OFF.
  1. Disconnect battery and wiper motor electrical connector.
  1. Remove the right windshield wiper mounting arm and pivot shaft and windshield wiper blade .
  1. Disconnect the battery ground cable (14301).
  1. Remove the right pivot nut and allow the windshield wiper adapter and connecting arm clip to drop into the cowl top outer panel .
  1. Remove the linkage access cover, located on the right side of the dash panel near the windshield wiper motor.
  1. Reach through the access cover opening and unsnap the wiper motor clip.
  1. Push the clip away from the windshield wiper adapter and connecting arm clip until it clears the nib on the crack pin. Then, push the clip off the windshield wiper adapter and connecting arm clip.
  1. Remove the windshield wiper adapter and connecting arm clip from windshield wiper motor crank pin.
  1. Remove nut and ground strap.
  1. Remove three attaching nuts from windshield wiper motor. Remove the windshield wiper motor .
Installation
  1. Position the windshield wiper motor and install the three attaching screws. Tighten to 13.6-19.0 Nm (10-14 ft-lb).
  1. Install nut and ground strap.
  1. Connect wiper motor electrical connector.
  1. Install clip completely onto right windshield wiper adapter and connecting arm clip. Make sure the clip is fully seated. Do not put the windshield wiper adapter and connecting arm clip on the motor crank pin and then try to install the clip.
  1. Install the left windshield wiper adapter and connecting arm clip onto the wiper motor crank pin.
  1. Install the right windshield wiper adapter and connecting arm clip onto the wiper motor crank pin. Pull the windshield wiper adapter and connecting arm clip onto the crank pin until it snaps into place. The clip is properly installed if the nib is protruding through the center of the clip.
  1. Install the right windshield wiper mounting arm and pivot shaft and nut. Tighten the nut to 9.5-12.5 Nm (84-110 in-lb). NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
  1. Connect the battery ground cable and turn the ignition switch on. Turn turn signal and windshield wiper switch off so windshield wiper motor will park, then turn ignition switch off. Replace right windshield wiper adapter and connecting arm clip access cover.
  1. Install the windshield wiper mounting arm and pivot shaft and windshield wiper blade assemblies on the pivot shafts to dimension X. Dimension X is the distance between the centerline of the blade saddle and the top edge of the cowl top outer panel grille. The value of Dimension X for each vehicle is given in the Dimension X chart in the Specifications portion of this section.
  1. Test the system.
Jan 04, 2010 | 1983 Ford Ranger
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Nov 14, 2009 | Garden
My fan doesn't start right away when the switch is turned on. Then as it is starting up it squeaks and hesitates. Seems like a "gunked-up" problem but I can't remove the impeller blade assembly from the...
The fan blade can be removed from the shaft. You just need to pop the lock washer off and pry the fan blade. You most likely will not be able to remove the fan blade without damaging the blade. You can buy the replacement fan blades online. The part number is 5901A000. Here is a blog on the entire replacement motor assembly. http://nutoneproducts.typepad.com/nutone-products/2009/08/nutone-0695b000-replacement-bath-fan-motor-for-model-qt80.html
Oct 05, 2009 | Broan-NuTone QT80 Fan
How to remove old and install new blade adapter (753-0609)model 759 on MTD mower--
Remove the blade bolt and blade, slide the adapter off the crankshaft. If it will not slide off, spray it with a good penetrating oil and let is soak for a bit then take a SMALL hammer and gently tap on the sides of it while pulling at the same time
Sep 07, 2009 | Mtd 22" White Outdoor Self Propelled High...
Can't get the drive coupling off my Bosch Universal to replace it
I have had my Bosch Universal Mixer with the Blender and Food Processor Attachments since 2005, and I've loved it since the day I got it... that is, until the blender broke while my son was crushing ice to make slushies...
I figured out the "drive coupler" was stripped and needed replacing, but I couldn't figure out how to take apart the "blade assembly" which includes the "drive coupler" part...
My retailer, Pleasant Hill Grain, sent me the following email:
"I am not aware of any printed instructions for removing the old coupling and
replacing with the new. We recommend holding on to the blades with 1 hand and a
towel and using a needle nose pliers to unscrew the old coupling. You would put
the new coupling on in the same manner.
If these instructions do not work, I would suggest contacting the Service
Dept at Kitchen Resources in Utah. Their phone is 800-692-6724."
I still couldn't figure out how to take apart the blade assembly, so I did end up calling the distributor, Kitchen Resources...
Dave, the tech @ Kitchen Resources, answered my call on the first ring...
Once I explained my problem, he started giving me the same instructions Pleasant Hill Grain gave
me... I explained to him that holding the blades tightly wasn't working for me.
As it turned out, holding the blades did not secure the drive shaft because
the drive shaft was broken off INSIDE the blade assembly - which is why I could
not unscrew the old drive coupling part.
Dave's next question revealed the true issue at hand... my Blender Attachment has the blade assembly made of plastic - they switched to plastic
in 2005 because the metal assembly turned black in dishwashers.
Bosch just recently went back to using metal for this part - apparently the
plastic blade assembly didn't hold up.
Kitchen Resources - the U.S. Bosch Distributor - is sending me a new blade
assembly - no charge, he said it's covered under warranty. Woo Hoo!
Best of all, I hadn't yet purchased the replacement drive coupling part, because
I wanted to know how to go about replacing the part before ordering a new part.
With shipping this part would have been a $50+ repair - you have to love
customer service of that caliber!
[Aside: You really don't need to ever put this part in the dishwasher - wash
the inside with by putting hot water and perhaps a little dish detergent inside
the blender and turning it on - rinse the outside under the sink... no
dishwasher needed! ]
Mar 23, 2009 | Bosch MUM6610 Universal Series Stand Mixer
Troy Bilt 5.5hp Self Propelled Mower Logo
277 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
