Question about Toshiba Computers & Internet
My screen shows multi colors unless I physically hold the screen up in one place near the frame. I have to do a fair amount of adjusting to get it to stay so that I can see whats on the screen. I have a Toshiba Satellite M45 S169.
    Sergeant:
  • 395 Answers
This is usually to to the graphics chip not being properly soldered to the circuit board - the chip is probably what is known as a ball-grid array and these are notorious for this problem.
If this is the case then you really cannot fix it and it will need a new mainboard.
If it is a loose connection to the screen then you may have a dodgy graphics cable which leads from the mainboard to the TFT display panel. Sometimes it may be that the connector on the mainboard is loose. If this is the case then it may be worth trying to take it apart (if out of warranty) and check that the multi-wire plug leading to the screen is firmly seated into the connector.
However, taking apart a notebook is quite tricky!
HTH
Posted on Aug 03, 2008
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
PANDIGITAL PHOTO FRAME
1. Remove the backing board and matte from the traditional frame, being careful not to get fingerprints on the glass.
2. Most likely, the cutout of the matte will be slightly wider than your digital frame's screen. If this doesn't bother you, skip this step. Otherwise, have a matte custom cut with an appropriately sized inner opening. (For the 8-inch Nixplay Edge, this is 6? by 4? inches.)
3. Place small pieces of poster putty on the front corners of your digital frame (see figure A). Then place the back of the matte gently on top of the screen. Adjust as necessary to align the screen. Then press firmly on the corners.
4. Secure the digital frame to the matte with pieces of wide masking tape.
5. Set the matte and screen into your traditional frame. Insert four frame spring clips (available at americanframe.com and some custom framing shops) to hold everything in place (see figure B).
Jul 17, 2016 | Photography
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Older 90's projection screen. 52 inch
Try opening up the front cover under the speaker outer cover, most speaker fronts should just pull off if you don't see any screws holding it secure near the side close to the front cover. Then there is about 4 or 5 screws that hold the front inner cover on. You are looking for a small black box with 6 adjusting screws . Three of these are for adjusting the focus and three are for adjusting the amount of current going to the CRT's. The markings are very small but you can try turning the Blue screw down and that will decrease the blue ( marked with a B). But if this just makes the other colors seem more powerful you may have a bad blue CRT. There is adjustments for three color CRT's ,Blue , Green and Red, try playing with the Blue and try to get it the way you think it should look but if the Blue just does not want to work right the Blue crt is probably gone.
Sep 10, 2008 | RCA P52926 52" Rear Projection Television
WEGA KDF-60WF655
It may be a fault at the line output transistor(loptr) it has tree legs and is usually bolted/clipped to a metal heatsink plate to keep it cool.
Its usually very near the LOPTX flyback transformer
Find the collector (middle leg) and follow the printed circuit till you get to the scan coil plug (looking for burnt pins as you go).
The width scan circuit consists of three main bits, the scan coils, the "S correction capacitor", and the linearity coils, they are all connected in series (any order)
First check the scan coils, The connections , (both ends) and the small pcb on the scancoils, then measure the resistance of them, 1 to 5 ohms is ok
Now find and test the S corrections cap ,its usually 220nf to 1uf at 250v-400v , look for burnt ends and/or swollen case
Now find the Linearity/width coils, these are fairly big , sometimes with an adjustable core
They measure very low zero on my meter. 1 or 2 ohms
3fcce55.jpg Better take it to a sony service station to check it.
Jul 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Hotpoint HS12 Hood - Charcoal Filters
vbab, loose charcoal isn't a problem unless it gets out of the frame that it is supposed to be in and lands on your stove top. A small amount may have gotten around whatever is supposed to hold it. No worries! Most units shove into place. Usually, that means pushing one end of the filter frame into the unit against a spring. You can then push the other end up so that it is caught by the cabinet of the unit. Moderate pressure is required.
Go to GE.com and find your instruction manual or, if not available, the GEs are nearly the same.
Nov 26, 2007 | Hotpoint  Standard Range Hood
Computers & Internet Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
