Question about Hoover WindTunnel Rewind Upright Vacuum Cleaner
T series started making noise and does not pick up like it did before. i did catch a shoelace just prior
Carpet attachment motor shut off and stops after a short time
Hi there, it's Jack at Dyson.
DC23 Motorhead's brush bar is engineered to shut off for protection if something jams it. This could occur if it catches something like a rug fringe or a shoelace, or if threads or hair are wrapped around the brush bar. To resolve this, please follow the steps shown in our Support video below to clear any debris:
I'm confident this will resolve the issue, but if you would like some further advice from our experts once you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 07, 2014 | Dyson DC23 Motorized Floor Tool
Brush stopped spinning and is sparking
Hi there Amanda, it's Jack at Dyson.
Unfortunately it sounds like the shoelace jamming the brush bar may have caused damage to the cleaner head. It's probably best if you can give our freephone Helpline a call so we can take some further details. If your machine is within our 5-year guarantee period, our experts can confirm if we're able to replace the cleaner head for you.
You can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
We'll look forward to speaking with you.
Mar 19, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Not picking up dirt
Have you tried cleaning out under te plastic cover? Remove it as you would when you replace the belt I get stuff caught in there or just inside hard metal tube there is a small magnet that will catch things and sometimes block it up. Use hose to **** it all out and clean. I find this helpful when it doesn't want to pick up as well I know it is time to clean it up.
May 16, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum, about 5 yrs old (bought new, no issues prior) - my 6yr old tipped it on it's side while water was in basin. Now when I turn the power on, it makes a very loud sound in the motor and you can...
Although a wet/dry vacuum, it cannot tolerate water in the motor. Water will cause the motor to short out, which will cause the motor to act/sound like yours does now, if it continues working at all.
To prevent additional problems, the vacuum needs to be taken to an authorized Rexair dealer for cleaning and repair. Expect at the very least to pay for a new motor and installation.
Problems like this are why I don't care for any wet/dry vacuums, especially spendy ones.
Oh, you should definitely discontinue use, and don't attempt repairs on your own. Special tools are needed, and if bolts and screw are rusted, breakage may result.
Feb 27, 2011 | Rainbow E series Canister Wet/Dry Vacuum
I ran over a shoelace and now the brush won't rotate. I have the healthy home bagless
Shoelace is probably lodged in the roller somewhere...you'll need to take the cover off as if you were changing the belt and look at the roller to see where the lace is and remove it ...if you don't remove it n try to run the lace out then you risk burning up a belt
Jan 22, 2011 | Bissell Healthy Home HEPA Bagless Upright...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Sounds like something is 'stuck' -
unplug, then unwind the shoelace from the roller.
Jun 15, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Power brush SEB234/236
Hi Clyde,
Before you start, unplug the vacuum from the wall socket.
First remove all the shoe laces from the beater brush. Then make sure the belt in installed correctly. If this doesn't correct the problem, open the unit and find any fuses that it may have and replace any that are blown. That sould correct your problem. It sure seems that vacuums get hungry for more than dirt at times. lol Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vacuums
Hoover WindTunnel Rewind Upright Vacuum Cleaner Logo
50 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
