Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Printer won't stop printing. Turn off and turn back on and it starts printing..
    Sniper:
  • 52 Answers
Perform a partial reset Perform a partial reset to restore the product settings to the default values.
  1. Write down any fax numbers and country/region and language settings stored in the product memory.
    CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
  2. Disconnect the power cord from the rear of the product.
  3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
  4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
  5. If the product does not turn on automatically, press the Power button (printer won't stop printing.  Turn off and turn - c01602202.gif ) to turn it on.
  6. Press OK to continue the current task.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Next solution
Dowload the Firmware fix on this line. make sure it's connected over the usb cable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77368-1&lc=en&dlc=en&cc=us&os=228&product=3795406&sw_lang=&key=null&site=null
Posted on Mar 26, 2011
It won't print. There's a print job in the cue that I cannot delete. I'm able to delete more recent ones, but not the first. Firmware is up to date. My fix before was to turn it off,...
Try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Oct 02, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Everytime I start my printer I get a message to realign while there is NO problem with the alignment.
The printer alignment has to be completed as below,
  1. After printer prints the alignment sheet.
  2. Place the printed sheet on the scanner bed and press "start scan" or "start color copy".
  3. Wait untill the printer Power light stops blinking.
  4. Now turn off the printer and turn back on.
  5. Printer will not print alignment sheet.
Regards
Riztech
May 29, 2011 | HP PSC 2175 All-In-One InkJet Printer
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
On this page
goes to my printers page right click on printer select open in print queue select print job the click on stop printing
Apr 20, 2009 | Computers & Internet
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Doesn't work.
Turn Printer off (printer is still connected, however to PC)
Start...run... "services.msc"... <enter>
Find the "print spooler" service, highlight it and stop the print spooler service (little stop icon)
Navigate to C:\windows\system32\spool\PRINTERS
delete all files (*.SHD and *.SPL) in that directory.
return to services window, and re-start the print spooler.
Close the windows that you've opened.
Turn printer back on.
Wait one minute.
Print something to printer.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Cannot get print operation stays on answering machine.
turn off your printer. then you chose start option from your windows. and click printer and fax option from above of hlep and support switch. and you can chose that printer in which you faced problem. and open that printer option. then you will see pending list of your printer. on that list you select all and do right click on that list and click cancel option.after cancellation of all the pending document. you turn on your printer. right now you can print as per wish.
regard
priyabrata (Be in IT)
Feb 16, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printer not working properly
The DeskJet printers are notorious for this problem. When you turn the printer off and back on in the middle of a print job, it gets confused when it is back on and cannot interpret the print language when it resumes from the computer. Whenever this happens in the future, you need to delete the print job off your pc before turning the printer back on. If you have windows XP, click START, SETTINGS, PRINTERS&FAXES, then double-click on your printer icon. When the queue window comes up, right-click on the active print job, select DELETE, then reply YES to confirm. If you don't see the print job delete (it might take a minute or so), then you will have to stop/start your Windows print spooler. Go to START, SETTINGS, CONTROL PANEL. Double-click the ADMINISTRATIVE TOOLS icon. Double-click the SERVICES icon. Scroll down and locate PRINT SPOOLER. Right-click on it and select STOP. Wait about 10 seconds, then right-click on it again and select START. Close out of the SERVICES & CONTROL PANEL windows. Open your printer status window again and see if it is clear. Once it is clear, it will be safe to turn your printer back on. Hope this helps.
Mar 05, 2007 | HP DeskJet 648c InkJet Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
266 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
