Question about Nordic Track Nordictrack 2500 R Treadmill Drive Motor
My nordictrack 2500 R will power up and the elevation will work but when i hit start the belt doesnt work and the whole thing powers down
2 Suggested Answers
  • 64 Answers
SOURCE: Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Posted on Nov 17, 2009
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
1999 pontiac grand prix gt squealing very loud when it hits operating temp
Check your power steering fluid , or you serpentine belt an tensioner !
May 29, 2015 | 1999 Pontiac Grand Prix GT
Power steering doesnt work well when cold
Squealing means the PS belt is loose or frayed. Replace the belt and adjust the tension correctly. The "bouncing" is caused by the PS pump starting and stopping because the belt is loose.
Sep 08, 2017 | 2002 Toyota Sienna
I own a Nordictrack 7000R and the console just quit working. It turns on like before, but now only speeds 3, 8 and 12 work...no other function operates...no start/stop, incline anything. I really love...
All electronics should have a surge protector. So when the power flickers and send a power surge to electronic plugged into the wall the circuit board is protected like your computer.
Nov 03, 2013 | Nordic Track NordicTrack Commercial 1500...
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
Only certain buttons on the NordicTrack exp1000 treadmill work.
1) You must check the flexible cord between display board vs controller motor board, and tight very well
2) Try to access to the keypanel and clean with special spray (clean contact you can find in radio schack or computer store).
3) Try to Measure the +5Vdc for I.C. including EPROM, ROM, etc.
4) And try again.
5) Measure if the power supply to display is coming out from the Lower board or Motor controller board. If not the Motor controller is faulty. You must replace it.
Use Dvoltmeter.
Remember 90% aprx the Motor controller board access to the function in the display board, elevation motor, power input, etc.
sincerely.
Nov 22, 2011 | Nordic Track Nordictrack Exp 1000...
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Its on incline 12 and wont go down. When i try to decrease it imakes sound like its happening but its not declining!!! Please help!!!!
Open front cover to see if there are any visible broken parts. If not try recalibrating the incline. If it doesnt calibrate you will more than likely need an elevation motor. The guide for the gear on these sometimes will break. The motor runs but gears arent on track.
Jun 06, 2009 | NordicTrack E4000 Treadmill
Nordic Track Nordictrack 2500 R Treadmill Drive Motor Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
