Question about MSI Wind U100-423ES Notebook
MSI u100, 2 years old, powers up (the power button is lit up) yet the screen is totally blank. I have tried restarting several times with different combinations of battery only, adapter only, or both but with no success. Urgently need help.
    Sergeant:
  • 223 Answers
Thank you for using FixYa
Hey I can understand your frustration. I have an MSI PR400 laptop and I had a similiar issue while it was new and in warranty. They put a new motherboard in mine. I read that you tried it with and without battery. Did you remove the battery completely and restart? There is a slight possiblity that it is the power supply not charging the battery. You say there is a green light, but is it green on the adaptor? If so the charger is probably good. If you are handy with electronics you could try to get a reading with a volt meter on the tip of the charger. I don't see an easy solution and you will probably endup taking it in for repair. Did you push the reset button? Some models have one. I wish I could help more but that is about it on a notebook since it is a closed unit. You will need to take it to a qualified service center.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 24, 2011
Testimonial: "Thanks Denny for the feedback. I think the adapter is working fine as the 'charging' light is on. Planning to take it to the support centre tmr. "
  • Pgor2012 Mar 14, 2012
    I am having a similar situation here withy 2 year old MSI U100. I tried all of the above - trying different power outlets, with and without battery and switched the on-off switch so many times. The screen flashes for a split second and though the power button is on and the unit is on( I can hear the unit is on) but the screen is black and no pushing or playing with the keyboard does anything.. Am at wits end!! Please please please help!!
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Power button not working
You didn't say Windows what? makes a big difference you gotta know. Have you tried a safe mode start up by tapping F8 a few times key right after Bios screen blanks & before Win. screen appears. Once in the boot menu choose safe mode. Let it boot then try decreasing the video settings & restart. if that"s not the fix restart in SM & uninstall video driver. It should reinstall a working driver on next start up.
Jul 13, 2013 | MSI Computers & Internet
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Computer monitor don't work at all.
So basically your monitor's power supply system died.
Nothing much a non-technician could do about it.
Get it repaired, if under warranty, get a replacement before the coverage duration expires.
Jun 07, 2010 | Computers & Internet
My msi wind wont start!!! i was trying to reinstall my windows using the recovery disk, so restarted my wind but mistakenly pressed f12 instead of f11 to run the boot set-up, but my screen froze (totally...
I'd like to help you, but it is very difficult to diagnose based on your description. We will need to gather more info as we try a few things.
1. Why are you reinstalling? 2. How old is the system? 3. Try the following & let me know the result: turn system back on. When the normal LED indicators are on, press & hold down the power button for 4+ seconds until everything goes off. 4. If step 3 worked, then turn power on & hit bios setup key (f2?). 5. See if HDD is detected.
Jun 07, 2010 | MSI Wind U100-030US Laptop
MSI WIND U100 won't start....
thats a lil odd seems as if the motherboard is trying to determine what speed of ram you have but after about five mins or more if it doesnt do anything try reseating the ram cards if after five mins again try using just one ram card in one slot if it turns on fully turn it off and move the same working ram card to the next slot if any slot fails then that ram slot is dead if you have more then one ram card test it using the same method if the ram card does not work then that ram card is bad
Apr 22, 2017 | MSI Wind U100-030US Laptop
We went to use our Toshiba L305D laptop. All lights are lit, but nothing shows on screen. Hold in power button to restart and computer sounds like it's rebooting. Screen is totally blank.
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
Jun 25, 2009 | Toshiba Satellite L305D-S5904 Laptop
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
MSI Wind U100-423ES Notebook Logo
352 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
