Question about Velodyne CHT-12 Subwoofer
Is there a picture on how to hook up acht-8/cht10/cht-12
    Brigadier General:
  • 8,546 Answers
Yup, in its manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Velodyne-CHT-12-Subwoofers-manual/id/866dj583/t/2/
Posted on Mar 24, 2011
I have a 2000 crown vic and my coolant fan wont come on unless i cut the a/c on or unplugged the cylinder head sensor i changed thermostat and temp sensor it still same thing what could be the problem
You have a wiring problem from sensor to the PCM - engine computer .
DL22 CHECK CHT SIGNAL CIRCUIT FOR SHORT TO GROUND
    Note: Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
  • Disconnect PCM.
  • Measure resistance between CHT signal and SIG RTN circuits and then between CHT signal and PWR GND circuits at the PCM harness connector.
  • the PCM is what controls the cooling fan !
  • This Pinpoint Test is intended to diagnose the following:
    • Cylinder head temperature (CHT) sensor (6G004)
    • Harness circuits: CHT, VREF, and SIG RTN
    • Powertrain control module (PCM) (12A650)
    Tables and Graphs
    On applications that do not use a ECT sensor, the CHT sensor is used to determine the engine coolant temperature in place of the ECT sensor. In this case the PCM may store both CHT and ECT Diagnostic Trouble Codes (DTCs). To cover the entire temperature range of both the CHT and ECT sensors, the PCM has a dual switching resistor circuit on the CHT input. A graph showing the temperature switching from the COLD END line to the HOT END line with increasing temperature and back with decreasing temperature is included. Note the temperature to voltage overlap zone. Within this zone it is possible to have either a COLD END or HOT END voltage at the same temperature. For example, at 90°C (194 °F) the voltage could read either 0.60 volt or 3.71 volts. Refer to the table for the temperature to voltage expected values.
    Voltage values were calculated for VREF = 5.0 volts. These values can vary 15 percent due to sensor and VREF variations.
  • DL1 DTC P1288 OR P1116: CHECK OPERATION OF CYLINDER HEAD TEMPERATURE SENSOR
    • Run engine at 2000 rpm until engine temperature becomes stabilized.
    • No Starts or Vehicle that Stalls:
      • GO to DL3 .
    • Check that upper radiator hose is hot and pressurized.
    • Rerun Key On Engine Running (KOER) Self-Test.
    Is DTC P1288 or P1116 present? Yes No GO to DL2 . Engine temperature was not stabilized. REPAIR any other DTCs as necessary. DL2 CHECK VREF CIRCUIT VOLTAGE AT TP SENSOR
    • Refer to schematic at the beginning of this pinpoint test.
    • Disconnect throttle position (TP) sensor.
    • Key on, engine off.
    • Measure the voltage between VREF and SIG RTN circuits at the TP sensor harness connector.
    Is voltage between 4.0 volts and 6.0 volts? Yes No There is sufficient VREF voltage. RECONNECT TP sensor. GO to DL3 . GO to C1 . DL3 CHECK RESISTANCE OF CYLINDER HEAD TEMPERATURE SENSOR WITH ENGINE OFF
    • Disconnect CHT sensor.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this pinpoint test for resistance specifications.
    Is resistance within specification? Yes No For No Starts or Stalls, RETURN to Section 3 , Symptom Charts.
    All others, GO to DL4 . REPLACE CHT sensor. You need a scan tool to do some of these tests
  • DL4 CHECK RESISTANCE OF CHT SENSOR WITH ENGINE RUNNING
      Note: Verify that engine is at operating temperature before taking CHT readings.
    • Run engine for two minutes at 2000 rpm.
    • Measure resistance between CHT signal and SIG RTN pins at the CHT sensor. Refer to the table at the beginning of this Pinpoint Test for resistance specifications.
    • Key off.
    Is resistance within specification? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPLACE CHT sensor. DL5 DTC P1289 OR P1290: ACCESS CHT PID AND CHECK VOLTAGE
    • Connect scan tool.
    • Access CHT V PID.
    Is the CHT V PID less than 0.2 volt? Yes No GO to DL6 . GO to DL7 . DL11 CHECK CHT SENSOR SIGNAL AND SIG RTN CIRCUITS FOR OPEN IN HARNESS
    • Disconnect PCM.
    • Measure resistance of CHT circuit between PCM harness connector pin and CHT sensor harness connector.
    • Measure resistance of SIG RTN circuit between PCM harness connector pin and CHT sensor harness connector.
    Is each resistance less than 5.0 ohms? Yes No REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuits. free wiring diagrams at www.bbbind.com
Jul 13, 2015 | Cars & Trucks
Hookup instrutions for a velodyne sub/amp serial number 63311523
manual is here:
http://www.velodyne.fr/index_htm_files/cht-8_cht-12_manual.pdf
Mar 19, 2015 | Velodyne CHT-8 Subwoofer
How do I set it up
... according to its manual and that of the upstream (unnamed) electronics.
One can be found here...
http://www.retrevo.com/support/Velodyne-CHT-8-Subwoofers-manual/id/866dj581/t/2/
May 28, 2011 | Velodyne CHT-8 Subwoofer
My CHT-8 powers on but doesn't have sound.
Check your receiver's speaker set up menu and make sure suboofer output is set to ON.
Jan 20, 2011 | Velodyne CHT-8 Subwoofer
I hear some noise coming out from the woofer of CHT-12R
It very well could be the spaker leads hitting the speaker cone.
You could check this by removing the amp section from the back.
Remove the screws at the very edge of the amp panel.
Jul 04, 2009 | Velodyne CHT-12 Subwoofer
Amplifier for my velodyne cht-8 is making noises
Yes the amp section can be peplaced.
Call Velodyne, the amps are not that expensive.
Jan 01, 2009 | Velodyne CHT-8 Subwoofer
Velodyne CHT-12 Subwoofer Logo
201 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
