Question about Ertl 580 Super M Series II Tractor
Parking brake is locked on my case 580 SM series III - what is the problem and how do I unlock them.
Why is the parking brake lock? how do i unlock it?
If the handle/ foot pedal releases, then it is the cables to the rear brakes that are frozen. You can replace them or cut them close to the rear brakes.
Dec 29, 2015 | Jeep Cherokee Cars & Trucks
580 sm series 2 pushes fuel out of top part of injector pump out of a rubber 90 degree fitting that looks like an over flow or releaf opening
there is a seal gone in the lower part of the pump needs to be removed and rebuilt . having mine done now complete rebuild cost 6 to 700$s
Feb 24, 2013 | Ertl 580 Super M Series II Tractor
I have a case 580 c and the differiental lock will not release causing it not to steer the wheels turn but the tractor wants to go straight
Disconnect linkage. Remove differiental lock housing located on right side of transaxle. Ck for repair issuses. Ck sliding gear, spring engagement, etc
Feb 20, 2012 | Ertl 580 Super M Series II Tractor
Brake light stays on after releasing parking brake pedal feels a little soft
Check the parking brake cable to make sure it is moving freely and allowing the brakes to completely release when you pull the release lever. Sometimes dirt and rust will lock the cable. In this case, the parking brake pedal will still sit on the switch even though it is unlocked because the spring can't pull it and the cable back to the off position.
May 19, 2011 | GMC Jimmy Cars & Trucks
Dual xdvd700
This unit is designed so that it may be operated only when the vehicle is in “Park” and the
parking brake is fully engaged. To this end, this unit includes a parking brake lock-out
feature which prohibits the unit from operating if the vehicle is not in “Park” and/or the
parking brake is not fully engaged. When installing this unit, the installer must connect
the parking brake detect wire (“Yellow-Blue Lead”) to the parking brake mechanism in
order to make the parking brake lock-out feature operable. DO NOT simply ground the
parking brake detect wire to a metal portion of the vehicle. Failure to properly install
the parking brake lock-out feature could lead to driver distraction which could result in
serious injury or death to the driver’s occupants or persons outside the vehicle and/or
property damage.
Once the parking brake lock-out feature is installed, the owner/user must not attempt to
disrupt/neutralize the parking brake lock-out feature by (a) partially engaging the parking
brake and/or (b) purchasing/using any device or unit designed to send necessary brake
signals to the unit. Failure to follow these instructions could lead to driver distraction
which could result in serious injury or death to the driver’s occupants or persons outside
the vehicle and/or property damage.
you could just earth the system straight to the veihicle, which will then dissengage the play in park feature, here is the website for the online manual
http://www.dualav.com/support/manuals/xdvd700.pdf
Mar 16, 2010 | Car Audio & Video
I forgot my password
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series and you have forgotten your 4 digit PIN number you can unlock the device by returning to your Security Location. The Security Location is the location that you set when you first enabled the Garmin Lock on your device. Returning to the Security Location will unlock your device. (Approximately 150 feet from that location)
If you have forgotten your PIN and Security Location please contact Product Support for assistance. Please note Garmin will require a copy of the receipt and there will be a charge to unlock the device as this issue is not covered by the warranty.
To contact Product Support in your area go to http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Nov 28, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Ertl 580 Super M Series II Tractor Logo
726 people viewed this question
Top Ertl Toys Experts
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
