Question about Datalogic Gryphon GM4100 Linear Imager Barcode Scanner
I'm trying to configure a GM4100 barcode scanner. To do this I want to add a suffix to the barcode (a tab charachter). I've done this before with the same type scanner. But now it doesn't work!!! I've rest the scanner multiple times. I scan the enter/exit programming mode, scan the barcode 'set global suffix', then I scan the 0 and 9, two times enter exit. But....nothing. It seems it doesn't go in programming mode? kind regards Albert
5 Suggested Answers
  • 279 Answers
SOURCE: Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
Posted on Aug 28, 2007
thesuperdude
  • 97 Answers
SOURCE: is it possible to send two suffix in symbol ls2208
Yes it is possible.
You will need to create the following adf rule which you can do using 123scan.
the barcodes generated will be the following:
Begin new rule.
Send all that remains
Send Extended key <Enter>
Send extended key <Enter>
Save Rule.
If you can't generate them, I can send you a pdf document with them already created.
Posted on Apr 02, 2009
  • 74 Answers
SOURCE: LS 2208. I have to add preffix ^ to Code 39 and suffix @ to
The easiest way to do this would be to write two Advanced Data Formatting rules using the LS2208 Product Reference Guide at this link (I suggest saving a copy then printing the pages from that saved copy)
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=118232754&stateId=0%200%2012083692
You should scan the following barcodes in order:
Begin New Rule Adobe page 232 of 342
Send All Data that Remains Adobe page 246 of 342
Send @ Adobe page 272 of 342
Save Rule Adobe page 232 of 342
Code 39 Adobe page 235 of 342
Send ^ Adobe page 275 of 342
Scanning the barcodes in this order will make the scanner send an @ after every barcode scanned other than Code 39. Code 39 barcodes will get the ^ before the data and an @ after the data.
Posted on Aug 03, 2009
prashant2012
  • 1127 Answers
SOURCE: I have a Symbol LS2208
HI
Download the Manual for LS2208 and go to page no. 255 there you will get you solution. for manual click hear.
Cheer
Posted on Jul 05, 2011
Gryphon GM4100
Which part of programming you required?Data Editing?Header/Terminator configuration?
Jul 14, 2014 | Datalogic Gryphon GM4100 Linear Imager...
How to configure motorola cs3070 tab suffix
Download the CS3000 Series Scanner Product Reference Guide from the Motorola Solutions Support portal and scan the barcodes:
<Data> <Suffix 1> Adobe page 69 of 152
Scan Suffix 1 Adobe page 68 of 152
7 from the Numeric barcodes Adobe page 121 of 152
0 from the Numeric barcodes Adobe page 120 of 152
9 from the Numeric barcodes Adobe page 121 of 152
Save Configuration Adobe page 72 of 152
https://atgsupportcentral.motorolasolutions.com/content/emb/docs/manuals/13608804a.pdf
May 05, 2014 | Symbol Hotshot LS2106 Handheld
]c1 : where to find the code to eliminate ]C1 when reading barcode EAN128 ?
Page 80, Section GS1-128 AIM ID Section of Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English)
Manuals
Aug 12, 2013 | Datalogic Gryphon I GM4100 Barcode Scanner...
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
How do i get my scanner to do "enter" without
Hello Severiano,
this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document. https://docs.symbol.com/attachments/ADC-01244.doc
Aug 02, 2011 | Symbol LS2208 Handheld
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
How do I get the scanner to automatically tab after a read?
Go to the Motorola support website and download the LS2106 Product Reference Guide. Print and scan the following barcodes:
Data Suffix 1 from Adobe page 80 of 112
Scan Suffix Adobe page 79 of 112
7 Adobe page 88 of 112
0 Adobe page 87 of 112
9 Adobe page 89 of 112
Once this is done the scanner will now send the tab after every barcode scanned.
Nov 03, 2009 | Symbol Hotshot LS2106 Handheld
I need to program a <tab>suffix character
Just go to page 8-6 and scan the "Enable Tab Suffix" Barcode that is 5th down from the top of the page. It took me awhile to figure it out too. Hope this helps someone since the question is a year old...
Jul 09, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Feb 07, 2007 | Wasp WWS800 Handheld
Datalogic Gryphon GM4100 Linear Imager Barcode Scanner Logo
1,363 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
