Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
  • 4,323 Answers
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Posted on Mar 26, 2011
Testimonial: "I was the latch that was broken.... a repair man came and the part was $65, and the labor was $100!!!!! UGH... at least my DW is working !! Thanks!"
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
Why won't my dishwasher start?
Thank you for your inquiry, friend!
Based off the information you have provided "CL" stands for close door. If you continue to experience an issue with the "CL" error code I would recommend having a professional come out to your home and diagnose your appliance. "CL" could be a problem within your door switch or main control board. Hopefully this is helpful. -Matt
Aug 28, 2014 | Electrolux Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
May 10, 2009 | GE Dishwashers
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Mar 10, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
1,129 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
