Question about Brother Disney PE-400D Computerized Sewing Machine
I have a Brother Disney SE-2700 and the bottom threads knott up causing me to not be able to sew.Please help.
  • 491 Answers
It sounds like it has not been correctly threaded or the tension is too tight. Check the tension discs for bits of thread that may have broken off and be causing a blockage.
Re-thread the top threads making sure the pressure foot is up before passing the thread through the tension discs!
Then check the bobbin is running correctly by pulling on the tail of the thread. The bobbin should rotate clockwise. Put the bobbin case in and make sure it is seated correctly.
If all this fails try replacing the needle. A blunt needle can cause all sorts of weird problems
Posted on Mar 24, 2011
SOURCE:
What is causing the bottom thread to knott up when sewing
Check the top thread tension discs, if not threaded right the stitch will knot up on the underside
Sep 14, 2017 | Sewing Machines
Brother se 2700 will not sew on knit fabric
Check that you are using a ballpoint needle, designed for knits. Also, be sure that the thread is not 100% cotton thread.
Jul 15, 2014 | Brother SE-270D Computerized Sewing...
I have a Brother SE-270D. The top thread is not
A bent needle will cause this. Otherwise the shuttle is out of time, have it serviced..
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
Tangled thread under metal plate
-The bobbin is too lose. Tight the adjustment screw on the bobbin case a little more and test, keep doing until it's good.
-Or possibly the upper threat is too lose so it won't pulls the bottom up as well.
-Check it out and adjust it.
Good luck
Mai
Jan 18, 2018 | Brother SE-270D Computerized Sewing...
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother Sewing & Embroidery SE-2700
How do you retime a machine? My machine will miss stitches ot completely break the thread. The top thread misses a lot of stitches.
Feb 22, 2008 | Yamata FY101-1A
Brother se- 2700 sewing/embroidery machine Comment by Loves2sew, posted on Jan 30, 2008 when pushing the thread cartridge in a piece snapped off the inside and I need a diagram to see where is belongs. It...
Brother se-2700 sewing/embroidery machine. My automatic thread cutter is getting very dull and won't cut any more. Can it be replaced? Where do I get a replacement?
Thanks porschegl
Jan 30, 2008 | Yamata FY101-1A
Brother Disney PE-400D Computerized Sewing Machine Logo
6,263 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
