Question about Cameras
Very short battery life - Cameras
  • 4 more comments
  • angelfox87 Aug 18, 2008
    my cameras battery life is extremely short. It doesnt even last a fully day if i use it more than a few times. Why?
  • Anonymous Oct 15, 2008
    I have the same problem, Fully charged batteries do not last more that 5 to 10 shots. Hoping someone has a solution for this. I know it's not the batteries.
    thanks ronnie
  • Anonymous Oct 31, 2008
    Same problem here as well. Sometimes 10 shots, sometimes 5 and if you try videos? Maybe 30 seconds and its gone! Perhaps a defective batch?
  • Anonymous Jan 13, 2009
    Our Samsung S730 gets maybe 3 pictures before the new batteries are gone.
  • Anonymous Mar 21, 2009
    I cant take more than 1 or 2 pictures without low battery showing up
    So I put in new batteries and the same problem occurs
  • J0t4 Apr 20, 2009
    i had the problem at fuji S5100. new batterys and 1 pic, max 2.
That's my problem also before. so when i asked their customer service they told me that i should use a rechargeable battery that is AA 2450 mAh because my old rechargeable batts are only 1800mAh and it's too low.. and after trying it.. it now works well and my battery life is longer :)
Posted on Jul 10, 2010
  • heartwing05 Jul 10, 2010
    that's my problem before with my camera. their customer service told me to use a rechargeable batt AA 2450 mAh. bcoz before im only using a 1800 mAh and it's too low. so after trying my new rechargeable batst my camera is now working well and the battery life is longer.
For the FE-210, infamous for its odd battery problems, insert 2 LI batteries, set quality to sq2, DONE, or i was lucky
Posted on May 10, 2009
How to improve battery life of Samsung AA-PB9NC6W battery
Dell is the worse laptop in this world. If anybody wants to buy a laptop, please think thousands time before you pick up NONSENSE DELL.
Jul 25, 2013 | Computers & Internet
How to improve battery life of Dell Inspiron 15R N5010 battery?
never leave your laptop on until the battery is out of charge
optimally, you can remove your battery after it's fully charged and keep your charger connected until needed.
Battery problem
you have some problem with batteries:
a) use the same right type from batteries
b) if you use rechargable , see if are FULLY charged, otherwise your device charger is defective, and replace batteries.
c) power supply is defective draining life for batteries go to the repair shop and fix it.
d) remember if you use too much the flash the life is short,+zoom
God bless you
Aug 02, 2012 | Cameras
Short battery life
If you are experiencing short battery life with a rechargeable batteries try the ff:
  • recondition the battery by draining the battery
  • charge the battery but when it is full reconnect the charger (do this until the charging indicator is not lighting even if you reconnect the charger)
  • try to use other batteries
Thanks
Hope this help
Byron
Sep 16, 2009 | Canon PowerShot A430 Digital Camera
Battery life seems fairly short. How long should
In most laptops the standard idle life is around 3 - 4 hours. The drain from the internet can cut this down to between 1 - 1 and a half hours. Using games is around the same or less than what the internet takes and if your using an office application it is around 3 - 4 hours.
Using the laptop for power hungry multitasking will reduce battery life dramatically.
Regards.
Aug 18, 2009 | Acer Computers & Internet
Battery life to short
Most re-chargeable batteries are 1.2V each, totalling 2.4V. The Z712IS Camera is designed for 3V operation. Therefore using 2 re-chargeable bats is not enough, UNLESS they are 3 or 3.7V.
Feb 23, 2009 | Kodak EasyShare Z712 Digital Camera
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
Short battery life
Get a replacement from Philips if it seems abnormal and you are still under warranty. 8-9 hours is normal battery life for this unit - the product specs are "ideal" - not relaistic. No way to dim this unit.
-tha mp3 doctor
May 12, 2008 | Philips SA5125/37 MP3 Player
Sprint V3M Short Battery Life / Won't Turn on
Make sure that you did not bend the pins installing the sd micro memory card. Its very easy to do and it will short to ground decreasing battery life significantly.
Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Short battery life
Try running the battery down completely (0% so it turns off itself), and charging whilst the phone is completely off (I'd suggest leaving it overnight). Repeat this once or twice, then see if your battery life has improved. Also ensure that you havent left anything on that could be eating your battery up i.e. bluetooth, and contact your supplier if the problem persists, as you should be covered.
Aug 28, 2007 | Samsung SCH-u540 Cellular Phone
Cameras Logo
1,571 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
