Question about Mirus (SIT17LCD) (Black) Monitor
On the internet and monitor went black. I restarted the computer and could hear the start up tone but the video is still black. Might it be a video card or the monitor itself? It is about 3 years old and stays on almost all the time.
  • 6,771 Answers
Chances are it is the monitor that is bad, but I would suggest hooking a spare monitor to the computer to rule out the video card, at least this way you will know for sure.
Posted on Mar 24, 2011
No beeps toshiba x200
IF neither your external Monitor or Laptop LCD screen are inactive, this generally relates to the Video Section on the mainboard a being compromised. The best solution is a bench test done by a technical professional to locate the excact cause.
Jan 07, 2014 | Toshiba Satellite X200-AA3 Notebook
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
I was playing solitaire on our home PC and the power went off and the screen went black. Before it went black it said "no input signal go to power save" Everytime I try to turn the computer on...
It means that your monitor is not getting a signal from your PC. Your monitor is fine though. You will need to plug the video cable from your monitor into the onboard video if you are using a graphics card. If you are not using a graphics card then you will probebly need to get a PC technition to diagnose the problem with your motherboard.
Feb 21, 2011 | Vision Computer (2U-A2200K) (2UA2200K)...
Ok..So I've had my tx2500 for a little over a year now (go figure, the warranty's out). After I booted up today, I went online and after a few minutes, the screen went pixel'y' and then went blank. The...
there is something wrong with the video driver or the monitor...If the screen shows something like the devices when it boots up...and only goes blak when it logs to windows...I mean if you see all on the screen until you get to the windows logo..this is a operating system error ..a driver seting or crash...so ...just reinstall it ..or repair the operation system ..cause if it is a setting on video driver or a error ..you can not fix it if you do not see anything ..
if the system boots but you never see a thing on the monitor...not even the writen devices when it first starts..or the bios..this means that the screen or the ribbon of the monitor has a damage on..try to change its position...or so ..but in this case you will need a ribbon for sure ...
Jan 31, 2010 | HP Pavilion tx2500z Notebook
Screen went black. when restarting the computer screen shows desktop for one second and goes black again
Always start with the physical when diagnosing a PC. First is the wire from the video card to the monitor fastened properly? and if so then turn off the PC open the case and make sure that the video card itself is properly seated on the motherboard.
Jul 18, 2009 | Computers & Internet
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
I changed Desktop resolution setting to higher, Monitor went black with "Out of Range" message
please try this:
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
2. Right-click the desktop, click Properties, and then click Settings.
3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
3. Click Advanced, click Adapter, and then click Change.
4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
6. Click Standard Display Adapter (VGA), and then click Next.
7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
9. Click 256 colors, click Apply, and then restart the computer.
10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
11. Click Device Manager, click View devices by type, and then click Display adapters.
12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
13. Install all updated monitor drivers.
hope it helps!
Nov 02, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Black screen have tried changing outputs but still black screen.
check for loose video connectors, power cables (of your monitor). Also try to turn off your computer by pressing and holding the power button. (you know your computer is off if it doesn't make any sound or vibration)
if all else fails, power up your computer and listen for a tone/beep sound. If there is a long beep sound probably your memory (RAM) is loose, defective or faulty. If you hear a tone/beep in a patern (like long-short-long, or any other pattern) then probably your VIDEO CARD is loose, defective or faulty.
Aug 01, 2008 | Computers & Internet
Mirus (SIT17LCD) (Black) Monitor Logo
20 people viewed this question
Top Mirus Computers & Internet Experts
Martin Murray
Masood Rasool
Level 1 Expert
Are you a Mirus Computer and Internet Expert? Answer questions, earn points and help others
