Question about LG WM2487H Front Load Washer
Need to remove boot seal to clean properly, and then re-install. How do I do it!? Email window will not respond: jimdok@hctc.com
    Brigadier General:
  • 3,513 Answers
Hi
Unplug the LG front load washer power cord from the electrical outlet. Turn off the water supply valves on the wall where the supply lines come into the house. Move the LG washer away from the wall so that you can work behind the washer.Place a bucket behind the washer and disconnect the two water supply hoses from the rear of the unit. Place the hose ends into the bucket. Remove the seven screws that secure the back cover of the control console with a Phillips-head screwdriver.
Push the control console forward so the face of the console rests on the top panel. Disconnect the wire connectors to the components inside the console. To make reassembly quicker, label each of the wires with masking tape and mark their location on the masking tape with a pencil. The connectors will come off by pulling them with your fingers. Move the control console away from the washer.Open the dispenser lid on the top left of the LG washer. Remove the four screws securing the dispenser to the top panel with a Phillips-head screwdriver. Push down on the dispenser and then lift the dispenser out of the top panel.
Slide a putty knife between the top and front panel 3 inches from the left front corner. Grab the dispenser hole with your free hand and pull up on the top section while depressing the retaining clip with the putty knife. Pull the top panel away from the washer.Locate the two screws on the top edge of the front panel and remove the screws with the Phillips-head screwdriver. Open the filter cover on the lower portion of the front panel and remove the screw from the filter cover with the Phillips-head screwdriver. Place a flathead screwdriver between both sides of the filter covers and pull the filter cover out of the front panel.
Open the washer door and pry the boot retaining spring off the door seal boot with a flathead screwdriver. Close the washer door.Tilt the top of the front panel toward you and locate the door switch connector toward the inside bottom of the door. Press the locking tabs on the door switch connector with your fingers and pull the connector off the door switch.Lift the front panel away from the washer.
Also check the bellow link if it helps:-
http://www.ehow.com/how_5651102_replace-front-load-washing-machine.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 24, 2011
Taylor model 754-27 soft serve machine getting water and soft serve in side tray on the the side of the machine. never happened before.
It's either:
A. The drive shaft boot seal - 032560 Boot Seal - You can buy them individually or as part of the tune up kit. They are normally replaced quarterly. Inspect this part when you take the drive shaft out for cleaning. It's very important that the drive shaft comes out every time you clean the machine and that you pack lubricant between the seal and the shaft.
B. The Shell Bearing - Taylor 031324 Replacement Rear Shell Bearing This is the metal sleeve that the drive shaft goes through in the back of the freezing cylinder. They wear out over time, they usually start to "mushroom" out grind down the boot seal.
031324-4 -5jpt2eusobswb402obrm5sjf-2-9.jpg Email me if you need a part or more help.
tex@softserveparts.com
Jun 07, 2017 | Taylor Ice Cream Makers
When I try to open my email,it write error code 800700B7
Step 1:
Follow the steps provided in the below link and check if it resolves the issue.
http://windows.microsoft.com/en-us/windows7/troubleshoot-problems-installing-service-pack
Step 2:
if step 1 fails, I would suggest you to place the computer in clean boot, then try to install stand alone SP1 package.
To place the computer in clean boot, follow the below article.
http://support.microsoft.com/kb/929135
To install SP1 stand alone package, visit the below link.
http://support.microsoft.com/kb/976932
You can also refer:
http://support.microsoft.com/kb/2505743
Aug 14, 2014 | Computers & Internet
How to fix systemwin32.rundll
First, shut it down, clean fan and vents, open and clean if necessary. Improve air flow from bottom through the laptop to side vents. A Laptop Cooler Pad is one option. Overheating will damage components and cause a catastrophic failure. I would run a FULL SCAN with Your UP-TO-DATE Anti Virus, Delete ALL results. ALSO, Download MALWAREBYTES freeware at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL SCAN, Delete ALL Results, Reboot. If you must, Boot to Safe Mode with Networking and download and run scan. Post the results and progress. For further assistance, respond to this post.
Jan 15, 2013 | Acer Aspire 4830t-6841 14" Laptop/notebook...
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
Mar 07, 2011 | 2000 Dodge Caravan
I have malfunctioning electric-driven exterior towing mirrors on a 1999 ford f-350. How to diagnose/fix? Mirrors respond only to right adjust; no response on up/down or left adjust.
there is a separate motor for up/down and another for left/right adjust. The glass is serviceable but not the motors, built into the frame of the mirror body.
SECTION 501-09: Rear View Mirrors 2000 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior rear view mirror glass in the full down position.
  1. Grasp the top and carefully pull the mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior rear view mirror glass.
Installation
  1. Remove the jack pins from the mirror glass back.
  1. Remove the sealing boots.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Install the jack pins in the mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
Jan 13, 2011 | Ford F-350 Cars & Trucks
My web cam is not detected
You may need to perform a clean install of the Logitech camera software if it didn't install properly or a another program in memory is conflicting with it. Removing the camera software and reinstalling it using a clean boot procedure may resolve the symptoms you are experiencing.
The following instructions will walk you through this process:
Remove the Logitech camera software.
  1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
  2. Open the Windows Control Panel.
  3. Open the Add / Remove Programs window.
  4. Locate the listing for the Logitech camera software and remove it. When prompted to remove the camera drivers files, click Yes.
Prepare the system for installation of the Logitech camera software.
    1. Go to the Logitech Downloads Page and select your product to download the correct version of the Logitech camera software.
    2. Please see here for the clean boot procedures.
    3. Doubleclick the icon for the Logitech camera software download file.
    4. Follow the on-screen prompts to complete the installation.
  1. Return Windows to its normal state.
    1. Use the instructions located here to enter MS Configuration window.
    2. Place checkmarks in the items that you previously removed them from.
    3. Click OK and allow the computer to reboot.
    4. Test the Logitech camera software to ensure your original issue has been resolved.
    Please ensure that you are using QuickCam 11.8 if you have Windows Vista or Windows XP
Dec 20, 2010 | Logitech QuickCam Express Web Camera
Help with j3
Hello sir, hi, J3 or JP3 is CPU Front Side Bus clock jumper setting (JP3) you can visit this link for adition al info: http://www.fixya.com/support/p281070-soyo_sy_k7vme_motherboard/manual-35533/page-12 .
Dont tell me you made a mess of the jumper settings, if you did, we need the manual for proper configuration.
If you have not modify the motherboard jumper settings, then your monitor problem is the graphics board.
If you have AGP card installed, remove the card and clean the contacts on the card, by using an eraser and the agp slot with a clean painbrush, reseat it on its slot afterwards. TEST. Do this several times until the PC respond, if not;
It could also be your main DDR memory, remove the module and clean it also, then reseat the module. Test.
Make sure that your DDR modules are good, If you are not sure, you may need to swap out an extra module for test. Or visit a friend who has the same module as your pc.
Do the swapping of the the modules several times until the PC respond.
Nov 20, 2009 | Soyo SY-K7VME Motherboard
1984 chevy g10 van - window seals are old and
yes you must remove all, or it won't seal properly
Jul 27, 2009 | 1985 Chevrolet Sportvan G10
How do i replace the front caliper seal on 06 malibu maxx??????
while the seals in the calipers are replaceable, its probably easier just to get a new/re manufactured caliper. if for any reason the seals don't work perfectly you could lose control of the vehicle when attempting to stop. with that said i'll try to explain the best i can how to replace the seals in the calipers for that vehicle.
1. jack up the front of the vehicle, place on jackstands and remove the front wheels, make sure the parking brake is on
2. unbolt the caliper and unbolt the brake line from the caliper and take caliper to a clean bench
3. remove the dust boot retaining ring on the caliper that holds the boot to the caliper itself
4. using a blowgun with a rubber tip apply low pressure compressed air where the brake line was bolted to the caliper to push the piston out of the bore (be carefull and ready because the piston may shoot out with some force)
5. when the piston comes out you will need to replace the dust boot and the seal so remove the boot and seal carefully so you don't scratch the piston ( the seal is actually in the caliper piston bore hole)and throw out the old seal and boot.
6. inspect all the surfaces and make sure there are no imperfections at all on the piston, the piston bore, or the caliper, if the surfaces are marred in anyway, replace the caliper, if they are good, using brake cleen and compressed air clean all parts then dry them
7. get the new seal and lubricate with DOT 3 brake fluid
8. install new seal into the caliper bore
9. apply a thin coat of DOT 3 brake fluid to the piston itself
10. install bottom half the the caliper piston into the caliper bore.
11. install new dust boot seal onto the piston
12. compress the piston to the bottom of the caliper bore
13. fully seat the dust boot seal into the caliper and install retaining ring
14. reinstall on vehicle (make sure to use a NEW copper washer on the brake line to caliper fitting) and bleed the braking system while checking for leaks.
repeat process for the other side.
if the caliper leaks at all from the piston after seal replacement, replace the caliper.
make sure you properly bleed the brakes before attempting to drive your car.
*these direction were extracted from personal experience and manufacturer information*
any other questions just ask!
Feb 20, 2009 | 2006 Chevrolet Malibu Maxx
NTLDR is missing
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
LG WM2487H Front Load Washer Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
