Question about Echo CS400 18" Chain Saw
My echo 400 chainsaw was working great and then it shut off. Now I cant pull the starter cord to start the engine. I pulled off the cover and it looks like the 2 pawls inside are engaged so that the spool will not turn..,...
  • Echo Master
  • 2,239 Answers
This does not sound good, start by removing the starter, try to turn the engine by hand turning the flywheel, move it back and forth incase there is somthing trapped between the flywheel, if you cannot turn the engine this way, then somthing bad has happened inside the engine, it will now require a strip down to find out exactley what has happened
Posted on Mar 26, 2011
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
Chainsaw starter rope won't pull
Pull your spark plug to ensure it isn't a compression issue or even piston/rod damage. If it still doesn't move, pull off your starter assembly and try to rotate the fly wheel by hand. If it turns, then your issue is in your recoil spring kit. You can replace the unit, or try to disassemble and reassemble.
Jul 30, 2014 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
Cant remember how to start my g100 wacker. Can pull the starter cord but forget where the little knobs need to be turned to
I am not familiar with your model but general rules are as follows. 1 - make sure that the gas'oil mixture is the right ratio and that the fuel is not stale. 2 - Depress the little rubber primer bulb 4-6 times, or until yor see little bubbles through the bulb. 3 - Rotate the choke lever to Full and pull the starter cord until the engine tries to start. 4 - Rotate the chole lever to Half and pull the starter cord until the engine starts.5 - After the engine warms up, rotate the choke lever to Run or Open so that the engine runs smoothly.
Jul 01, 2011 | Garden
Pull cord is frozen...can't pull to get engine started
Remove the starter cover. does it rotate freely?
Yes - Investigate why engine is seized.
No - Locate appropraite IPL (exploded parts list), opeb approate drawing, remove and replace defective parts. HTH
Lou
Oct 01, 2009 | Homelite Garden
The pull cord has come off the spindle, how do I get it back on properly or install a new one and reset the spring tension
Remove the starter cover, rewind or wind a new cord onto the spool. Turn the spool about 2 turns against the spring, thread the pull cord through the starter cover and reinstall the pull handle.
Lou
Sep 05, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Apr 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Echo CS400 18" Chain Saw Logo
338 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
