Question about Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit
Bostitch n80s nail gun leaks air at the trigger.. I need instructions as how to remove the trigger assembly and replace with a new one. I have the new trigger assy.. Any help will be greatly appreciated...
  • 2,176 Answers
Under my name click on it and in the tip section on the left hand side of the page you will find detailed instructions on how to remove this valve. If you have trouble finding it let me know and if I have helped you with your problem would you please vote accordingly, Thank you
Posted on Mar 25, 2011
Trigger is leaking air and trigger is not working on a bostitch coil nail gun
replace trigger valve assembly aka tva 6 you can get aftermarket ones fairly cheap that are just as good. it is fairly easy to do, usually takes about 10-15 min, lots of how to on you tube look under bostitch rn46 trigger
Oct 31, 2013 | Stanley Bostitch Rn461 Gun Coil Roofing...
I have a Bostitch N80S stick framing nailer that leaks air from the trigger area. I replaced the entire trigger valve with a new single fire trigger to see if the old bump fire trigger was the problem
Remove the nails and take off the trigger to expose the trigger valve (usually part # tva6). Connect air and spray soapy water on the valve to determine if the air is leaking from the center of the valve or around the outer edge between the body and valve. If leaking from the center, could be defective valve or debris under oring. Pop out the valve and examine internal parts for cut oring or defect. If leaking from between body, you could have cut orings installing the valve. Make sure that there are no rough edges in the body of the gun. Bump fire or single fire happens with the trigger type not the valve. Bump fire trigger is usually black metal and single fire trigger is light color plastic. Good luck
Apr 10, 2013 | Stanley Bostitch Nail Gun
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I have a framing nail gun and air is leaking around the trigger. How do I get the trigger off to replace it or replace the rings?
in the tip section I have detailed instructions on how to remove the trigger valve assembly. You might be able to click on my icon to get to the page, let me know if you need more assistance.
Sep 06, 2011 | Stanley Bostitch Nail Gun
Leaking air through trigger area. Will not nail at all.
The trigger valve has seven orings. The oring kit may not include all orings needed. To replace the trigger valve, remove nails, remove the rollpin holding the trigger with 3mm driver to expose the trigger valve. Next remove one or two roll pins holding the trigger valve in the body of the gun. Apply air pressure to gun and catch the valve with gloved hand (use caution because the valve may come out with force). Note the position of the valve in the body of the gun in relation to the roll pins. If the firing pin seems loose in the body of the valve, replace the whole valve(could be # tva6 cost about 20 dollars on ebay). Good luck
Aug 23, 2011 | Stanley Bostitch N80s Nailer -rebuild...
Instructions to install trigger assembly in n60fn air nailer
Easy to do. Use 3mm roll pin punch to remove pins at trigger and one or two pins just above the trigger valve in the body of the gun. With pins removed and trigger out, nails removed and with a gloved hand, apply air pressure to gun to pop out the valve. Use caution because the valve will come out with force if air pressure is too high (reduce air pressure at compressor). Make note of grooves cut into the old trigger valve in relation to how the valve was aligned and held in with roll pins. New tva6 valve is sold on ebay for under $20. Good luck
Jul 28, 2011 | Stanley Bostitch Nail Gun
How do you fix/repair 15 guage nail gun o-ring for the nail gun triger. air is leaking from the triger
the trigger assembly would need replaced. I have detailed instructions in the tip section on the removal and installation of the trigger valve. Let me know if you still need more assistance.
Jul 07, 2011 | Stanley Bostitch Nail Gun
Air is leaking at the trigger on a Bostitch 80s b1
Your nailer uses a trigger valve (could be part # tva6 cost about $20, need to look up) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions
Oct 06, 2010 | Stanley Bostitch N80s Nailer -rebuild...
Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
Apr 08, 2009 | Tools & Hardware - Others
Air leak on framing gun
You can repair this gun. Parts and breakdown are at www.bostitch.com look for service /parts and enter your model number. There you will the parts available for purchase. You will need the tva11 trigger valve. Easy to install. Remove roll pins that hold trigger and trigger valve. Remove the trigger to expose the tva11 valve. With the roll pin/s removed that hold the trigger valve you will be connecting air supply. Use heavy glove to catch valve as you apply air pressure. You may reduce pressure to airline to reduce pop-out force. Before you install the new valve check port for sharp edges and debris. Good luck with your repair.
Mar 16, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Bostitch N80s Nailer -rebuild Parts O`ring & Seal Kit Logo
206 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
