Question about kawasaki 10 Million Candle Spotlight Green
My 10,000,000 candle power spot light wont take a charge is there a simple fix or is it common for the resister to go bad?
How to tell if eggs are bad?
very simple and usable tip
i wish it helps
Jul 04, 2014 | Home
Tip
Double Candel light when the electric goes off.
This is a very simple tip to help you in your lighting needs when the electric goes out because of a storm or other occurrence.
Place a candle in a safe non-burning holder. Set the candle about a foot away from a clean mirror. Make sure there is no chance of anything catching fire from any accident or closeness. You will see that the reflection from the mirror gives much more light. This will help in conserving other candles also.
ElderV
on Feb 23, 2010 | Garden
Can u use a 12 volt charger to charge a 6 volt spot light 1000,000 candle power s800g
obviously not as the 12 volt will fry anything 6 volt. It is like putting 240 volt into 110 volt and wondering why it blew up. Get the right charger for the unit and save yourself heartache and money
Aug 12, 2013 | Camping, Backpacking & Hiking
Hdd light blinks red and won't start.when ac adapter is plugged in the screen is blank when on battery starts working for a couple of seconds and then is dead again. when i leave the battery to charge...
i rand spell check on you. fixed,
ok its a laptop/notebook.
nice full model number , rare here and bravo that.
we have like 10,000 posts here with Laptop dead.
endless , to the extreme, and did you take that bad large battery out first and leave it out and run on AC power only ? yes/no.
we ask that every time, 10,000 times, did you?
did you get text that way on the screen.??????
my wild guess is it runs ON AC battery out, but failed to say that.
so the big battery is bad, like all are now.
this old, batteries, are weak technology, they fail soon and hard.
just like cars, and your flashlight.
for 100 years now,+ never trust any battery and WIN ! (rule of life)
  • so does it turn on /w big battery out , ac pack connected and with AC power,yes /no.?
  • if yes do you get text ever.? on the screen?
  • do you get windows ,(is this vista>? login? or win7?)
  • do you attain the windows desktop? ever?
BEST I CAN TELL THIS PC IS 10 YEARS OLD (as old as)
it will need a new main battery and a new coin cell RTC.
all do that old, non serviced. for 10 long years.
batteries dont last , like electronics do.. not even close.
sorry, but that is battery makers weakness not HP or MS or anyone elses//
one more dead battery, post #10,000
this answer is only partial, after all , your inputs failed to tell how the pc ran with not main battery.
if we started there, the path to a cure would be different.
if answer was NO.
testing is a serial process and in correct order
that is why no simple guessing works. see?
Nov 10, 2017 | HP HDX16-1370us (NV032UA) PC Notebook
How do i find charger for cyclops 15 million candle power
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
May 19, 2010 | Camping, Backpacking & Hiking
Spot light doens't work
The battery is probably defective, take the battery out and test it, it should be at 12 volts.
Feb 28, 2010 | RoadPro 1M Candle Power Spotlight 12V
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
The charge in my milli cancdle power light lastsat the most 3-5 m
Your problem is almost certainly a bad battery. The fact that it lights for 3 to 5 min after each recharge indicates that the charger is good, and the battery wont take or hold a charge. That is my guess. Batteries Inc stores carry these batteries and are very helpful they also have a website: www.batteries-inc.com
Oct 14, 2009 | Camping, Backpacking & Hiking
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Voltage for spot light
input 120v 60hz 9w output12vdc 300ma model#D12-300
Jul 02, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
kawasaki 10 Million Candle Spotlight Green Logo
257 people viewed this question
Top kawasaki Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a kawasaki Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
