Question about Kenmore Dryers
Drum runs but no heat? - Kenmore Dryers
  • 1,998 Answers
the situation of a dryer not haveing heat can be attributed to a number of differnt parts finding out which one is not working properly would require you to use a multimeter and test the continuity in each part. In all dryers there is a hi and a low thermostat this is what tells the unit that it is either getting to hot and to shut off the heater or its time to turn back on the heater due to the tempreture being below what the factory set parameters are to dry you clothes. following testing the hi and low you can also test the heater by doing also a continuity test on this as well these are the three main parts that short and sometimes if you dont take apart the unit at least once a year and de lint your unit this will cause this type of situation. If all these three are in proper working order then you would have to look at the wiring, the motor , and the timer but usually the problem is within the first three parts mentioned if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations. Thanks Rick
Posted on Mar 24, 2011
My dryer is running, but doesn't have heat.
All electric dryers use 220-240 volts of electricity to run. The elements that make the heat are what actually need the 220 volts, the motor that turns the drum only uses 110. If you have a fused service disconnect box, replace both fuses, as one side is gone. 220/240 is made up of two 110/120 lines coming in, if one fuse, one side, blows, then all that's left is the 110/120 needed to run the drum motor, but no 220/240 to run the heat element. If there is no service disconnect then check the breaker than runs the dryer, flip it off and then back on to see if that makes any difference. Sometimes it will. Then there's the possibility that the hi-limit thermostat on the heat chamber in the machine blew, letting the drum run, but not feeding the coils. If you're not real handy with tools you may want to call a repair tech for this one.
Apr 22, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer starts but will not stay running
This is what is probably going on. There are two parts in the motor that cause the drum to rotate.
One of them is "start" winding. It literally starts the drum's rotation. Once the drum motor has started the drum to move. The second portion of the motor, known as the "run" winding takes over and keeps the drum turning. When the Drum winding burns out. The same symptom is caused when the switch attached to the motor is also damaged. In your case, although this is rare. I think it may be the switch.
The reason being is that the motor has a combination switch that also connects one side to the heating element. In a nutshell, If you get the dryer not continuing to turn AND the heating element stays on. There is a problem with the switch.
If you get the heating element going on when you push the start button but turns off when you release the button. The problem is the motor having a burned out run winding. Either way, it is less labor intensive to replace the motor when you take it out. Doing it switch is not easy. Hope this helps. If not write back to me and we can continue.
HAVE A HAPPY NEW YEAR
Best, Mark
Jan 01, 2011 | Kenmore Dryers
The dryer ir running but no heat
Initially sounds like the heating element(s) are burnt out. Probably needs replacing. The top should be removed and the drum removed, be sure to note the routing of the belt around the drum and pulley on the bottom. Once the drum is out, you can see the heating elements, but look behind the drum once the top has been flipped back, it may be accessable without removing the drum.
Feb 10, 2010 | Whirlpool Dryers
My druer is heating but the drum wont spin
either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Sep 30, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
Dec 26, 2008 | Whirlpool LGR8648 Gas Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Drum runs, but no heat
i would first look at the heating element. check for continuity.
Feb 08, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
