Question about Acer Aspire 5315 Notebook
Backlight on display went dim
I have had my Acer Aspire 5315 for 2 months and the backlight seems to have gone out on the display. You can barely see anything on the screen. I can take a flashlight to it and see enough to adjust brightness, cpntrast, etc., but this does not help. Still too dark to see...Any ideas?
  • Acer Master
  • 13,433 Answers
If the backlight has failed or a cable is loose you can replace or repair the backlight of the monitor.
replacement parts are available at
www.pchub.com
www.acerparts.com
I suppose the keycombination FN and arrow up or down has no effect?
Posted on Aug 03, 2008
  • Ekse Aug 04, 2008
    Is this laptop still covered by warranty? as its only two months old Acer should fix this for you all free. contact your dealer he will give you the number to call.
Acer aspire one screen barely displayed
There are two causes, the inverter board, " just under the LCD screen" more likely, or the backlight behind the display, "less likely"
Apr 18, 2012 | Acer Aspire One PC Notebook
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
Have an Acer 5315-2153 with 15.4 screen went black
Cheack your video with and external monitor, if you have video then you will need replace your inverter or backlight or both, if your lcd it is nor cracked this is a common problem with the lcd.
You need to remove your frontal plastic in order to see your inverter, if this didnt work replace your backlight.
\this is a heavy job if you didnt have the experience or tools, we can replace your inverter/backlight for $75 usd
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
vcrtech@hotmail.com
www.vcrtech.com
Apr 29, 2009 | Acer Aspire 5315 Notebook
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Acer 5515 backlight problem
Defective CCFL backlight may has the following symptom:
Apr 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5315 Notebook
My son had this problem with his Acer Aspire making a popping sound and the screen going blank, What do we do to solve this problem? Acer Aspire 5315-2077 Thank you for any assistant.
Does the popping sound seem to come from the bottom of the screen, near the middle, or just above the keyboard, in the middle? If so, the inverter board (which takes battery voltage and bumps it up to voltage high enough to run the display backlight) could be shorting out. If you connect an external monitor, and THAT keeps working, then my suggestion might be correct. The inverter board is not expensive, but the labor to replace it is.
Mar 03, 2009 | Acer Aspire 5315 15.4-inch Notebook PC
My acer aspire 9300 screen is very dim and I cant seem to get it brighter . I can barely see the icons?
Try resetting the laptop to default settings in the BIOS. If that don't work, sounds like there's a problem with the backlight in the LCD Display.
Most laptops come with Ambient Light Sensors, that can adjust the display based on the lighting in the room.
Dec 03, 2008 | Acer Aspire 9300 Notebook
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5315 Notebook Logo
330 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
